Hi all,
I am moving and I have some stuff listed on Ebay plus some stuff currently not on Ebay. Also willing to make a deal outside of Ebay for the stuff listed there if preferred. Combined shipping available. You can contact me here, through Ebay for that stuff, or at dan at sosdan dt com. Thanks.
Stuff not on Ebay:
2xAdire Audio Extremis 6.8 8 ohms good condition $70 + shipping each
4xHivi M4N magnesium alloy 4" midrange $10 + shipping each
2xVifa XT19 19mm silk ring tweeters $35 + shipping each
CDT QES1220 4 ohm SVC 500WRMS 12" subwoofer small sealed box working good condition $140 + shipping w/o the box $160 + shipping w/ the box http://www.sosdan.com/sellingstuff/dec2012/qes1220-1.jpg
2xAvel Lindberg 500va 2x115vac to 2x25vac model Y236801 good condition barely used $60 + shipping each http://www.sosdan.com/sellingstuff/aveltransformers.jpg
24x TI OPA134P single channel op amp $.50 + shipping each
Triad F5-12 transformer 12.6VCT 1A secondary 115VAC primary $5 + shipping datasheet http://www.mouser.com/ds/2/410/F5-12-223106.pdf
(4 avail) Dayton RS180-4 7" Car woofers 4 ohm component used tested working fair condition 4 Avail Dayton RS180 4 7" Car Woofers 4 Ohm Component Used Tested Good 844632054242 | eBay (2 sold now 2 avail)
(4 avail) Focal 6M115 6.5" midbass/woofer/midrange speaker 8 ohms home car audio 4 Avail Focal 6M115 6 5" Midbass Woofer Midrange Speaker 8 Ohms Home Car Audio | eBay
8 avail Nippon Chemi Con 50v 68000mfd 68000µF 68mF new 105c capacitors amplifier 8 Avail Nippon Chemi Con 50V 68000MFD 68000?F 68MF New 105C Capacitors Amplifier | eBay
Amplifier/Preamp Chassis ATI Research aluminum new DIY ATI-649PR 17"x10.5"x2.4" Amplifier Preamp Chassis ATI Research Aluminum New DIY ATI 649PR 17"x10 5"X2 4" | eBay
SOLD Amplifier/Preamp Chassis ATI Research aluminum new DIY ATI-661U 17"x10.5"x3.7" Amplifier Preamp Chassis ATI Research Aluminum New DIY ATI 661U 17"x10 5"x3 7" | eBay
Pair of Dayton Audio 1-1/8" silk dome tweeters 275-070 new in box manual 1800hz Pair of Dayton Audio 1 1 8" Silk Dome Tweeters 275 070 New in Box Manual 1800Hz | eBay
Vifa silk dome tweeter D26NC55-6 8 available new 6 ohms 50WRMS 91dB/2.83v/1m Vifa Silk Dome Tweeter D26NC55 6 8 Available New 6 Ohms 50WRMS 91nu l l28 3V | eBay
feedback at Heatware and Ebay under username ddfromma
Stuff not on Ebay:
