I am selling my Carvin amp for the single reason that I got a good deal on a Crown K2. The carvin amp has a few months of light use on it for my home theater subwoofer. If I didn't tell you other wise, you'd swear it was brand new!
I am asking $250 (shipping included) obo. If you are in southern california and are willing to pick it up, make it $225 (I am at UCI). This amp is normally $337 + tax.
Some specs
NOTE: RMS as in run it all day at these levels without any problems type RMS
Bridged Continuous RMS:
4 ohms 600watts
8 ohms 450watts
Both Channels Continous RMS
2 ohms 300watts/ch
4 ohms 250watts/ch
8 ohms 125watts/ch
Frequency Response: ±0.5 dB, 20 Hz to 20kHz (±1.5 dB, 10 Hz & 40 kHz)
THD (1/2 power): 0.03% 0.03%
Damping Factor: >350 >400
Slew Rate: bridged mode >45v/µs >45v/µs
Sensitivity: (4ohms, Vms) 1.0 V 1.0 V
Signal to Noise Ratio: Above 100 dB
Input Impedance: >20K ohms, balanced
Protection Circuits: • Short Circuit • No Load Protection • SpeakerGuard™ • Thermal Shut-Off
• Mute On/OFF
Control and Indicators:
Front: • Power switch • Recessed detent attenuators • Signal LED • Clip LED • Protect LED • Power Indicator
Rear: Ground Lift (each channel) • Parallel Input Switch • Speaker Output Bridge Switch • Limiters IN/OUT Sw • Input Connectors: Two each; Balanced XLR & 1/4” • Speaker Output Connectors: 3 Twist-Lok, heavy-duty binding posts and two 1/4” phone jacks
Dimensions: 3 1/2" High x 10" Depth x 19" Wide (2-space)
Some specs
4 ohms 600watts
8 ohms 450watts
2 ohms 300watts/ch
4 ohms 250watts/ch
8 ohms 125watts/ch
• Mute On/OFF
