Hi, I've got 3 available in 4 ohm, All are new and in original packaging.
Please let me know if you have any questions.
More photos available, just ask.
£120 each shipped in the UK, will ship to other countries just ask for shipping quote.
SPEAKER MODEL
12PS100
SPECIFICATIONS
Nominal Basket Diameter
12" / 320mm
Impedance
4 ohms
AES Power Rating
700 Watts
Program Power 1,400 Watts
Frequency Response
45Hz - 1.0kHz
Sensitivity (1W/1m)
93dB
Voice Coil Diameter
4" / 100mm
Winding Material Copper
Former Material Glass Fibre
Winding Depth .83" / 21mm
Magnetic Gap Depth .4" / 10.5mm
Flux Density 1.05T
MOUNTING INFORMATION
Overall Diameter 12.56" / 319mm
Bolt Circle Diameter 11.8" / 299mm
Baffle Cutout Diameter 11.1" / 282mm
Depth 4.7" / 120mm
Flange & Gasket Thickness .625" / 16mm
No. Of Mounting Holes 8
Net Weight 19.4 lbs./ 8.8 kg.
THIELE-SMALL PARAMETERS
Resonant Frequency (fs)
44 Hz
Impedance (Re) 5.3 ohms
Electrical Factor(Qes) .29
Mechanical Q (Qms) 3.9
Total Q (Qts) .27
Compliance Equiv. Vol. (Vas) 47 Liters/1.6cu. ft.
Voice Coil Overhang (Xmax) 8.0mm
Reference Efficiency 1.3%
BL Factor 22.5 T-M
Coil Inductance (Le) 2.0mH
SPEAKER MODEL
12PS100
SPECIFICATIONS
12" / 320mm
Impedance
4 ohms
AES Power Rating
700 Watts
Frequency Response
45Hz - 1.0kHz
Sensitivity (1W/1m)
93dB
Voice Coil Diameter
4" / 100mm
Flux Density 1.05T
Depth 4.7" / 120mm
44 Hz
Total Q (Qts) .27
BL Factor 22.5 T-M
