Started my Frugel Horn build, have all wood cut and sides shaped. As a starting point does it only need 40g of damping at the front and back only. Using Pluvia 7.2 HD drivers.
Thanks, it just seems like a small amount compared to the space it needs to feel. I'll have to carefully measure it out and fluff it up a lot.
All it needs to do is dull the eigenmode's 'sharpness'.Thanks, it just seems like a small amount compared to the space it needs to feel. I'll have to carefully measure it out and fluff it up a lot.
Fill?
If that is the case you probaby haven’t teased it well enuff.
dave
- Full Range
- Frugel-Horn Mk3 amount of damping
