Hi people!
I'm a DIY loudspeaker n00b looking for free (or very cheap) crossover design software, something along the lines of CALSOD. Any suggestions? Links? Info?
I'm building some vented 2-way floorstanders with Jaycar (Aus designed) 6.5" polycone mid/woofers and 1" Vifa tweeters. I've been reading Dickason's loudspeaker design cookbook and now have some idea regarding crossover design but i don't really feel confident enough to design them myself. I'm shooting for reasonable bass and good imaging, mainly for 2 channel, alt-rock, metal and electronic music use.
I'm fairly happy about what i'm going to do about the cabinet, but i get the feeling that XO design is the real art of loudspeaker design, so i'm basically after all the info i can get. Books are good, but real people are better...
Thanks in advance...
Speaker Workshop comes to mind. Watch out for more updates of the packages from the FRD Group.
As for commercial software, the Australian-made SoundEasy is probably the best value for money right now. It may not be cheap (at US$250), but it the best and most feature-rich in its price range. But wait for Ver. 6, which will add T/S extraction, distortion, motor and suspension non-linearity extraction etc. as well as enhancements to its existing electrical and acoustical measurement system.
Isaac
(I just found out we can't edit our messages after 30min.
Isaac
koen, D25AG-35s have been described as too zippy, bright or in your face
But you won't be disapointed if you've been used to the sound of metal tweeters. Consider the XT25TG30-04 as well. It has a nice flat response down to <1kHz, which helps your mid/woofer a bit by not having to cross too high into its breakup region. 2kHz+ would be a good start, but that's just looking at the datasheet. Someone with actual experience with the drivers will have to take over from here
Andy G. has worked with the above-mentioned drivers as well as some Jaycar units
Rob, I'd rather figure out SE than SW
I agree that SE's interface could use some rearranging, but it seems to be what tinkerers and engineers prefer or at least they're fine with it
Windows LEAP, now that's one package I'm eager to see. All that talk about needing a killer PC to realize its full potential has got me thinking what the new version can do.
Isaac
Isaac
That's what i'm worried about - the speakers being too 'bright' - but the low Fs sold me, i'd read that you could cross these quiet low (~1800Hz) with good results. The mids i'll be using aren't great, so...
I suppose that if they're irritatingly bright i could add some high frequency attenuation to 'dull' the top end response, yeah?
- Free XO optimising software?
