Free Energy devices
Comes to think of
a pre low noise pre amplifier
where
power supply was like this, to avoid mains ripple and such:
One normal transformer supply
was set to produce current into some LED lightening diodes
This light was received
by photo diodes in other side
So the only power (very low power) into pre amplifier circuit
came from this OPTO COUPLED function.
I would call this a very extreme design.
And I am not sure it would give any advantages
over a more traditional way to create a clean low power supply.
Like for example use battery.
lineup 😎
Lineup Audio Lab & Info
The Department of Strange Designs
I'm sure a few have been waiting for me to add to the subject. (Cringing or otherwise)
I personally don't think of any device, real or imagined, to be an auctual 'fee energy' device, I feel the idea calling it 'free energy' is a misnomer. "Over Unity" would be a more accurate name for the whole idea.
As for any device working, that's the long haul. For example, take a look at this video (Warning! high data rate, 50 minutes long!):
http://video.google.com/googleplayer.swf?docid=2229511748333360205
And always remember, that the scientific establishment was against Louis Pasteur...and was against microbes and small form biology (what ever you may want to call it), even though the evidence was right in front of them, in microscopes and reported and recorded by nearly hundreds of researchers....this...FOR TWO HUNDRED YEARS!
So, for 'over unity, to be wrong, with HUNDREDS OF RESEARCHERS weighing in..on the POSTIVE side of the equation.....well..both history and science has repeatedly shown the 'disbelieving' position to be.....patently ludicrous. Time, and time, and time, and time again, this has been the result. Ie, hundreds upon hundreds upon hundreds of positive results..are not wrong. Hundreds of different people and results. From hundreds of locattions across the globe.
Whether a given group wants to believe it or not, is the issue. Those stalwarts in hot fusion and ....oil,and gas, politics, globalist oriented ecomomies/countires, and military,etc....have everything to loose by it being true; that such technologies work.
It would turn all their worlds, directions and desires......completely on their heads.
You do the math.
The human is the issue here, not whether any given 'over unity' technology works or not.
So you guys play with the pre-existing world, live in the comfort of whatever it is you seem to desire with that mindset; - that I seem to be wholly incapable of understanding - and that's a good thing.
I'm struck dumbfounded by such backward thinking, this incredible inability to risk, to think outside the box. I am literally..deeply offended. In all seriousness. I am offended. To the core. Not in a nasty way, but deeply saddened - by your inability to grow wings. By your fear. Fear of what? Being ostracized? For what?
What does it matter, the opinions and thoughts of a given closed-in and backward man?
Show me your strength, not your weakness.
I’ve preciously tried to build a magnet motor but it didn’t work, like I have expected
It would rather be much more efficient and easier to use paranormal powers to generate electricity, think about that, but I’m not going to waste my time about thinking about that one because I don’t believe in that stuff.
Back to the real stuff:
Like say, if you want to build a electromagnet with the same power than those small little magnets so strong to cant take it of a another magnet, you will probably need a +7kw electromagnet and a water-cooled system to water-cool your electromagnet from fussing it self to a ball of metal.
So why not just take a magnet and do something with it and generate some electricity from the thing?
I'm no expert in physics and I'm not even very well educated(hate to admit), so forgive me if this doesn't all make sense.....
A magnet cannot be used for "free energy" or "over unity" energy.
First, you have to consider that it takes energy to create a magnet in the first place. Even if it was created in nature it still required energy to create.
Now that the magnet is made it is nothing more than a potential energy "storage device".
Example: When a magnet attracts a piece of iron it does so with this stored energy. Now that they are stuck together nothing else happens. To get the two pieces separated to where the attraction can happen again; you have to use another source of energy.
So basically you will never get any more energy out of a magnetic device than you are putting in. And most of the time it will be far far less.
Feel free to bash my feeble attempt at explaining this.
SY said:
The First Law is common sense once you understand the basics. A very nice explanation!
Thank you. It is in fact some very basic common sense knowledge that I personally learned as a child playing with magnets.
My mind seems more cluttered and chaotic as an adult; and sometimes I wish I could go back in time to where I was able to just sit and think clearly about such things.
"Free energy"
I am disappointed sometimes with those who think that all in the inventor circles are closed minded & don't think "Out of the box".....there are legions of corporate & independent thinkers out there whos' sole job is to think up new & revolutionary ideas.....To think that most are bound & limited by the "Laws-of-Physics" is an insult to the creativity of the human condition.
As to the 'corporate' entity' that puts a damper on revolutionary inventions is also not thinking correctly...A corporation that 'discovered' such a device/process would first of all secure the patent rights....and as the system proves itself viable this corporation would turn itself inside out to accomodate this new technology.
How do you think industry coped when at the turn of the century transportation changed from horses to the internal combustion engine? Horsemen turned into factory workers...Blacksmiths turned into foundry workers.
I do firmly believe that over unity devices are the modern day equivalent of snake oil & that imperical experimentation of said devices makes their "inventors" slither back into the woodwork...never to be seen nor heard of again.
____________________________________Rick...........
I think that if you made the over-weight ladies (and men) in the YMCA work out on a generator instead of a tread-mill it would be the moral equivalent of free energy -- turning white wine and Sara Lee coffee cakes into ergs.
regrettably, 90% of the folks who work out at our Y have a BMI less than 25 so this probably won't work.
As I once read, I can't remember where:
The three laws of thermodynamics -
1: You can't win
2: You can't break-even
3: You can't get out of the game
Phrased like that, they're easy to remember and understand...
