You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
Hi does anyone know of the 16w,40w max 'foster 035M1301' driver on a 100x160 square base, whether it's a mid range or a tweeter?
It has a fairly large dome 1.5in and the system is a bit top end shy, compared to my little two way set up.
Cheers Willy.
