Take it all for $230 shipped FREE to Canada & US
Mosfets:
Take it all for $49 for this GROUP
1 sets of 4 Matched IFRP240 (+/-3.5%) - $8 per set
1 sets of 4 Matched IFRP240 (+/- 1%) - $10 per set
1 set of 4 Matched IFRP9240 (< +/-1%) - $12 per set
(or = 1 set of 8 Matched IRFP9240 +/-2% - $24 per set of 8)
4 IRF610 - $4 for 4
4 IRF9610 - $4 of 4
4 SK216 - $4 for 4
2 SJ79 - $2 for 2
BJT's:
Take it all for $19 for this GROUP
2 - 2SC2922 - $9 for 2
2 - 2SA1216 - $9 for 2
2 MJE15031 - $2 for 2
12 MPS4250 PNP - $2 for 12
Diodes:
Take it all for $6 for this GROUP
12 MUR415 4A 150VDC - 12 for $5
2 IRF HFA15PB60 15A 600V TO247 - 2 for $2
Opamps:
Take it all for $32 for this GROUP
4 AD797AN (DIP8 case) $16 for 4
3 AD825 (SMD) $7 of 3
3 OP42FZ (Epoxy -8 Case) $7 for 3
2 AD844AN (DIP8 Case) - $5 for 2
1 AD817AN (DIP8 Case) - $2 for 1
Digital IC's & Lasers:
Take it all for $29 for this GROUP
1 Philips TDA-1541A - $15
1 Philips TDA1541 - $5
1 Crystal CS8414 24Bit Digital Filter on Adapter Board - $10
1 VAM1202/12 (CDM12) Laser Assembly - $8 for 1
1 28 Pin SMD to DIP Adapter Board $2 for 1
4 Sockets fro DIP-style ICs - Various $1 for 4
Capacitors:
Take it all for $22 for this GROUP
200+ New small electrolytic caps- Various including OSCons Elna Nichicon etc
$19 for the lot
25+ New/Used Large Electrolytic Caps - Variou
$7 for the lot
12+ Film caps (mostly used & a few new)
$2 for the lot
Relays:
Take it all for $15 for this GROUP
Mini DPDT 5V coil 2A@30VDC /0.6A120VAC contacts
$7 for 7
1 Mini DPDT 24V coil 1A@30VDC contacts
$1 for 1
E-T-A Circuit Breakers
2Amp 10/10 New $5 each
8Amp 10/10 New $5 each
16Amp 8/10 Used $5 each
or $10 for all 3
PCB Boards:
Take it all in this GROUP for $35
ALW Tracking Regulator Boards (Full Documentation PDF supplied via email)
2 Positive Boards $9 for 2
2 Negative Board $9 for 2
4 Line Driver Bare PCB Based on DRV134 IC
$8 for 4
2 Dual (+/-VDC) Power Supply Bare PCB (Non-Regulated Power Supply)
$8 for 2
3 Power Supply Diode Bare PCB Geared for HexFred or MUR1560 etc
$6 for 3
1 - Completed Regulator Board Dual + Outputs $3 for 1
Feet, Knobs & Spikes:
Take it all for $12 for this GROUP
4 varoius feet (1 pair of each) - $1 for 4
20 Various Aluminum/Plastic Knobs - $5 for the lot
3 Threaded Steel (chromed Spikes) $5 for 3
Machined Feet SS for DIY Enclosure - $5 for 3
Cables & Connectors:
NOTE: Take it all in this GROUP for $25
18 ft of Various Raw interconnect Cable - Coaxial & Balanced construction
$5 for 18 ft.
3 Pin Male XLR Connector (to make your own cables)
$5 for 4
3 Pin Female XLR Connector (to make your own cables)
$10 for 10
Female 3 Pin XLR to RCA Female Adapter
$4 for 2
3 Pin XLR Female to Female Gender Changer Adapter
$3 for 2
Neutrix Metal Female 3-Pin XLR Jacks
$3 for 2
2 BNC Cable Plug to make a BNC - BNC cable (using coaxial cable) $4 for 2
3 Pin XLR Male to Male Gender Changer Adapter
$1 for 1
2 BNC Jacks 75 ohm
$3 for 2
200+ 2mm spacing - Connection Housings 2-4-6 Pins types
$4 for 200+
Switches , LEDs, heatsinks & Miscellaneous:
Take it all in this GROUP for $30
3 4PDT Switches (On-On) NEW
$5 for 3
17 Various Switches
$4 for 17
~25+ Soft touch bushbutttons - micro-size
$5 for lot
1 Large (7" X 1.25" tall) Heatsink
$3
5 Ceramic Heatsink Isolator for TO-220
$2 for 5
2 Hammond Chokes 1000uH 1A ( PN # 1536Z)
$4 for 2
8 Various LED's with support/cases
$2 for 8
Philips CDM-4 Tray Gear & Belt 10/10
$9 for 2
25Kohm Stereo Ladder Attenuator
8/10 Condition
$10
PayPal is accepted for payment.
Shipping is free if you purchase $75 or more of multiple items
Mosfets:
4 IRF610 - $4 for 4
4 IRF9610 - $4 of 4
4 SK216 - $4 for 4
2 SJ79 - $2 for 2
BJT's:
Diodes:
Opamps:
Capacitors:
$19 for the lot
$7 for the lot
$2 for the lot
Relays:
$7 for 7
$1 for 1
or $10 for all 3
PCB Boards:
$8 for 4
$8 for 2
$6 for 3
$5 for 18 ft.
$5 for 4
$10 for 10
$4 for 2
$3 for 2
$3 for 2
$1 for 1
2 BNC Jacks 75 ohm
$3 for 2
$4 for 200+
$5 for 3
17 Various Switches
$4 for 17
$5 for lot
$3
$2 for 5
$4 for 2
$2 for 8
$9 for 2
8/10 Condition
$10
