I have the following items for sale:
1 Philips TDA1541A DAC - 1 for $10 (used)
2 Philips SAA7220P/B Digital Filter 2 for $10 (used)
5 OPA37 Single Opamp (DIP) - 5 for $3 (new)
5 OPA27 Single Opamp (DIP) - 5 for $3 (new)
5 BB OPA602 Single Opamp (DIP) - 5 for $3 (new)
5 BB OPA606 Single Opamp (DIP) - 5 for $3 (new)
5 BB OPA2111 Dual Opamp (DIP) - 5 for $3 (new)
3 BB OPA2132 Dual Opamp (DIP) - 3 for $3 (new)
2 BB OPA2107 Dual Opamp (DIP) - 1 for $1 (new)
2 Linear Technology LT1115 Opamp (DIP) - 2 for $5 (new)
2 Linear Technology LT1364 Dual Opamp (DIP) - 2 for $5 (new)
2 Linear Technology LT1128 Opamp (DIP) - 2 for $5 (new)
2 Linear Technology LT1124 Opamp (DIP) - 2 for $5 (new)
4 Linear Technology LT1028 Opamp (DIP) - 4 for $10 (new)
9 Signetics 5532 Dual Opamps - 9 for $3 (used)
2 Generic 5532 Dual Opamps - 2 for Free (used
3 LM833 Dual Opamps - 3 for $1 (used)
10 Nichicon Muse 47uF 50V Bipolar Caps - 10 for $4 (new)
1 NOVER 10000uF 50V PS Capacitor - 1 for $5 (new)
9 Jamicon 1000uF 63V 105°C PS capacitor 9 - $3 (slightly used)
1 EPCOS 2700uF 40V 105°C Snap-in PS Capacitor - 1 for $1 (used)
2 Chemicon 100uF 400V PS 105C 2 for $3 (slightly used)
2 Chemicon 56uF 400V PS 105C 2 for $2 (slightly used)
4 Sanyo 470uF 100V 105C PS Capacitor 4 for $2 (slightly used)
2 Sanyo 2200uF 35V 105C PS Capacitor 2 for $1 (slightly used)
2 Axial 30uF 450V PS Caps - 2 for $1 (new)
1 Nichicon Muse 1000uF 50V KZ PS Capacitor - $1 for $1
4 0.1 Film 1000V Capacitor $4 for 2
1 Rifa 420 2.7uF 400V PP Film Capacitor $1 for 1 (used)
1 Wima MKP-10 1.0uF 400V PP Film Capacitor 1 for $1
1 Evox MMK 2uF 400V Film Capacitor - 1 for $1
1 20uF 400V Film Capacitor 1 for $1
10 1uF 63V film Capacitors - 10 For $2
10 0.1uF 63V Film Capacitor - 10 for $1
2 11.28Mhz Crystal - 2 for $2 (used)
2 Gold RCA Female Jack (red) - 2 for $1
2 Gold RCA Female Jack (black) - 2 for $1
5 Circuit Board 2" X 3" (432 holes with Copper soldering holes) 5 for $2
10 On-semi Schottky 40A 250V PS Diodes - 10 for $5 (new)
10 On-semi MUR1540 15A 400V PS diodes - 10 for $5 (new)
4 On-semi MUR1520 15A 200V PS diodes - 4 for $2 (new)
8 On-semi MUR8600 8A 400V PS diodes - 8 for $4 (new)
6 On-semi MUR1560 15A 600V PS diodes - 6 for $3 (new)
2 On-semi MSR1560 15A 600V PS diodes - 2 for $1 (new)
2 24 Pin Mill-Max IC Socket (Fits SAA7220 DF) - 2 for $1 (new)
1 28 Pin Mill-Max IC Socket (Fits TDA1541A DAC) - 1 for $1 (new)
10 8 Pin Mill-Max IC Socket (for DIP Opamps)- 10 for $2 (new)
5 LM337T Negative Regulator - 5 for $2 (new)
5 LM317T Positive Regualtor - 5 for $2 (new)
4 10A Bridge Rectifier 4 for $2
4 5K TrimPots - 4 for $1
Take everything $125 US with FREE shipping to Canada/USA (lower 48)
Otherwise shipping will be $2-$7 for items (in bubble envelope) depending on the size of the order.
Thanks,
P.S. PayPal is the preferred payment and I will deliver using Canada Post
Thanks,
Added More Parts - See Below
1 Nichicon Muse 1000uF 50V KZ PS Capacitor - $1 for $1 new
4 0.1 Film 1000V Capacitor $4 for 2 new
1 Wima MKP-10 1.0uF 400V PP Film Capacitor 1 for $1 used
1 Evox MMK 2uF 400V Film Capacitor - 1 for $1 used
1 20uF 400V Film Capacitor 1 for $1 used
10 1uF 63V film Capacitors - 10 For $2 new
10 0.1uF 63V Film Capacitor - 10 for $1 new
2 Gold RCA Female Jack (red) - 2 for $1 new
2 Gold RCA Female Jack (black) - 2 for $1 new
5 Circuit Board 2" X 3" (432 holes with Copper soldering holes) 5 for $2 new
4 10A Bridge Rectifier 4 for $2 new
4 5K TrimPots blue enclosed like Alps - 4 for $1 new
I added the following to sweeten the deal! All are NEW unless stated otherwise.
4 4A 600V Bridge Rectifier 4 for $1 (slightly used)
3 10000uF 16V Nichicon PS Capacitor 3 - $1 used
1 6800uF 16V Nichicon PS Capacitor 11 - Free used
2 1000uF 35V Nichicon 105C PW PS Capacitor 2 -$1 (slightly used)
3 Constant Current Source - 1N5307 3 for $5
3 Constant Current Source - 1N5314 3 for $5
4 120 ohm 1W Allen Bradley Carbon Composition Resistor 4 - $2
3 160 ohm 1W Allen Bradley Carbon Composition Resistor 4 - $1
6 Current Inrush Limiter 5A #5R006 6 For $2
6 Current Inrush Limiter 10A #10R007 6 For $2
6 Current Inrush Limiter 14A #14007 6 For $2
6 Current Inrush Limiter 2A #2R006 6 For $2
3 Female XLR Jack - 3 for $3
4 Enclosed Fuse Holders - 4 for $1
5 Terminals -Solder Type - Standoff - Tube circuits 5 for $1
2 Nichicon 1uF 250 PP Capacitor 2 for $1
1 Jantzen 0.05mH 18g air core inductor 1 for $1
1 Jantzen 0.10mH 20g air core inductor 1 for $1
16 15VDC Zener 1Watt axial 16 for $2
4 1.5A Slow Blo Fuse 4 for $1
1 Lynk 10W Metal Oxide Resistor 1.0ohm 1 for $0.50
1 Lynk 10W Metal Oxide Resistor 1.5ohm 1 for $0.50
1 Lynk 10W Metal Oxide Resistor 2.4ohm 1 for $0.50
2 Lynk 10W Metal Oxide Resistor 3.0ohm 2 for $1
4 Lynk 10W Metal Oxide Resistor 3.6 ohm 4 for $2
1 Lynk 10W Metal Oxide Resistor 3.9 ohm 1 for $0.50
2 Lynk 10W Metal Oxide Resistor 4.3ohm 2 for $1
2 Lynk 10W Metal Oxide Resistor 5.6ohm 2 for $1
4 Lynk 10W Metal Oxide Resistor 6.8 ohm 4 for $1 leads cut slightly
1 Lynk 10W Metal Oxide Resistor 8.2 ohm 1 for $0.50
2 Lynk 10W Metal Oxide Resistor 12 ohm 1 for $1
5 Lynk 10W Wirewound Resistor 8.2 ohm 5 for $2.00
2 Lynk 10W WireWound Resistor 4.7 ohm 2 for $0.50 cut leads
2 Lynk 10W Wirewound Resistor 5.6 ohm 2 for $0.50 cut leads
Take everything $150 US with FREE shipping to Canada/USA (lower 48)
Thanks,
__________________
Thanks,
__________________
Added Photos of the Parts
I have the following parts for sale:
Thanks,
Thanks,
Dan, you're at it again--driving me nuts!!
Here's a list for yah;
And what are these??
8 On-semi MUR860 8A 400V PS diodes - 8 for $4 (new)
1 BB OPA2107 Dual Opamp (DIP) - 1 for $1 (new)
Thanks,
Let me know if these are available. I'm in N.Y.
Hey Philip (thefragger):
The items available are available as follows:
3 Constant Current Source - 1N5307 3 for $5 - Available
3 Constant Current Source - 1N5314 3 for $5 - Available
6 Current Inrush Limiter 5A #5R006 6 For $2 - Available
6 Current Inrush Limiter 10A #10R007 6 For $2 SOLD
6 Current Inrush Limiter 14A #14007 6 For $2 SOLD
6 Current Inrush Limiter 2A #2R006 6 For $2 - Available
8 On-semi MUR860 8A 400V PS diodes - 8 for $4 (new) - Maybe (2nd on list)
1 Philips TDA1541A DAC - 1 for $10 (used) - Maybe (2nd on list)
2 11.28Mhz Crystal - 2 for $2 (used) Available
1 28 Pin Mill-Max IC Socket (Fits TDA1541A DAC) - 1 for $1 (new) - Maybe (2nd on list)
1 BB OPA2107 Dual Opamp (DIP) - 1 for $1 (new) Available
4 120 ohm 1W Allen Bradley Carbon Composition Resistor 4 - $2 - Available
5 Terminals -Solder Type - Standoff - Tube circuits 5 for $1 - Available
Email me dmullins at cogeco dot ca to discuss.....
$25 total for all the items "identified as available" shipped to you
UPDATED Parts List
5 BB DiFet OPA602 Single Opamp (DIP) - 5 for $3 (new)
5 BB DiFet OPA606 Single Opamp (DIP) - 5 for $3 (new)
2 Generic 5532 Dual Opamps - 2 for Free (used)
4 0.1 Film 1000V Capacitor 4 for $2 new
2 On-semi MSRF1560 15A 600V PS diodes - 2 for $1 (new)
Take everything for $110 US with FREE shipping to Canada/USA (lower 48)
Thanks,
Thanks,
UPDATED LIST -Revision 2
Take everything for $90 US with FREE shipping to Canada/USA (lower 48)
Rest of the world will be additional $10 shipping (for the whole lot)
Thanks,
P.S. PayPal is the preferred payment.
Thanks,
UPDATED LIST - Revision 3
1 Nichicon Muse 1000uF 50V KZ PS Capacitor - $1 for $1 (new)
4 0.1 Film 1000V Capacitor 4 for $2 (new)
4 10A Bridge Rectifier 4 for $2 (new)
3 160 ohm 1W Allen Bradley Carbon Composition Resistor 4 - $1 (new)
3 Female XLR Jack - 3 for $3 (new)
4 Enclosed Fuse Holders - 4 for $1 (new)
2 Nichicon 1uF 250 PP Capacitor 2 for $1 (used)
4 1.5A Slow Blo Fuse 4 for $1 (new)
1 Lynk 10W Metal Oxide Resistor 1.0ohm 1 for $0.50 (new)
1 Lynk 10W Metal Oxide Resistor 1.5ohm 1 for $0.50 (new)
1 Lynk 10W Metal Oxide Resistor 2.4ohm 1 for $0.50 (new)
2 Lynk 10W Metal Oxide Resistor 3.0ohm 2 for $1 (new)
4 Lynk 10W Metal Oxide Resistor 3.6 ohm 4 for $2 (new)
1 Lynk 10W Metal Oxide Resistor 3.9 ohm 1 for $0.50 (new)
2 Lynk 10W Metal Oxide Resistor 4.3ohm 2 for $1 (new)
2 Lynk 10W Metal Oxide Resistor 5.6ohm 2 for $1 (new)
1 Lynk 10W Metal Oxide Resistor 8.2 ohm 1 for $0.50 (new)
2 Lynk 10W Metal Oxide Resistor 12 ohm 1 for $1 (new)
5 Lynk 10W Wirewound Resistor 8.2 ohm 5 for $2.00 (new)
Take everything for $80 US with FREE shipping to Canada/USA (lower 48)
Thanks,
Thanks,
