I know you should always clean off flux after soldering but I've been lax in this practice up to now! (I didn't realise how corrosive this stuff was)
But I just had a Set Top Box that stop communicating with a PC - when I opened it up I saw the problem.
About a year ago I had soldered some small OsCon caps onto smd caps on the board. Now smd caps with Oscons attached were lifted off the board - obviously I had not cleaned off the flux and it had eaten away at the glue holding the solder pad onto the board.
This is the first time I've experienced this - I didn't use too much flux or heat & the joints were solid & shiny when I made them - just like they should be. The pcb is probably not the most robust but still!
Has anybody experienced this before?
I'm worried about all my other soldering which I'm going to now try & clean up with alcohol - is ordinary spirits Ok for this?
