Hello, looking to do my first build. Want to make a monoblock to power my new center channel. Any recommendations? The center will be 2 ea 10" Hartley 220's, 2 ea Eton 4" hexacone mids, 1 JBL 2405 tweeter and 1 7" Hartley tweeter. I've been to the DIY Store and still need some help deciding. Thanks
In terms of output / performance, what sort of sensitivity spec do you think your speaker build will deliver?
Also, what's the predicted impedance?
If the speaker sensitivity is decent and the impedance is 8Ω or above, then the ACA is an easy, simple, safe way to get started. You can run it as a monoblock:
https://cdn.shopify.com/s/files/1/1006/5046/files/ACA_Monoblock_Operation_RevA.pdf
So, it might be a good fit.
If I run it as a monoblock what would the output be? I'm imagining there are instructions on how to do that
To me it seems a bit of "waste" of class A watts to use such an amp for a center speaker?
For "cinema sound" a higher watt class A/B may be better?
Or do you specific look for a Pass class A amp for this purpose?
Or is it "just" DIY that has 1. priority?
What do you mean "output"?
Check the linked document. It states power output specs.
I was looking for a little higher watt production say around 40 or so. It will be doing a lot of music as well. DIY is important to me
Check here:
FIRST WATT PRODUCTS
The amps noted as not available new, outline your options. Others on the forum can counsel you with regard to configuring a stereo amp as a monoblock and the power output you could expect. I wouldn't think it would be a straight forward doubling but I'd expect that it should be within what us Ozzies call "coo-ee" of that.
FIRST WATT PRODUCTS
is there a build guide for the M2? was hoping for a kit as a beginner I need all the help I can get. what do you think about the MOFO? looks simple as well4 Ohms box?
build M2 , 50W at 4R
I think it's important to know what you will be using as source(s) and the respective output voltages of those sources.
You will (maybe/most probably) find lacking gain if you are driving the FW amps with say a CD-player output and/or TV with something around 2V only.
For MoFo you WILL need some sort of pre-amplifer anyway!
Been there...
Max
Been there...
Max
- first build
