Fine-tuning turntable speed by changing belt thickness?
The inner diameter always remains the same, no matter how thick the belt is.
The belt diameter must be correct and the speed must be adjusted
using the available means, internal or external speed controllers.
Hugo
"Careful analysis of flexible drive belts will show that the effective radius of a pulley is the measurement from the center of the pulley to the neutral axis of the flexible belt (the plane in the belt where stress is zero as it is curved around the pulley), which is near, but not exactly at, the center of the belt. Simply stated, the thickness of the belt factors into the calculation of the drive ratio of the pulley and platter."
This analysis was discussed in a previous diyAudio thread that I am currently unable to locate.
The effective radius of the two pulliey's is the effective dia of the pulley/ 2 + ( 1/2 the dynamic thickness of the belt.) You''ve just defined the neutral axis of the drive.
From the neutral axis you can calculate the the ratio between the two pully's effective diameter IF the drive pulley is very small in relation to the driven pulley and the belt is thick yes it can make a difference.
Reactions: mikey_audiogeek
Agree with the "neutral axis" concept explained above.
In addition: with a compliant belt, tension and grip on the belt also affects speed because the tension and friction affects the position of the effective neutral axis, it is no longer at mid-thickness once the surfaces are constrained against sliding. Typically, increasing the tension slows down the rotation speed due to this effect. Reducing the tension can result in a slight speed increase as the neutral axis is allowed to return towards the unconstrained position. Until the belt loses traction.
Beyond that: adding a non-stretchy layer to the outside or inside of the belt also moves the neutral axis, changing the speed ratio slightly.
Try it and see. It seems to be one of the more misunderstood principles in turntable design, despite being taught as part of Mechanical Engineering degrees. Many machines use belt drives, so the science is well understood.
It's good practice to separate critical functions - speed control is best effected by controlling the speed of the drive pulley. Then the belt characteristics and tension can be optimised for other parameters such as lowest noise, optimum bearing load, startup behaviour, dynamic response, maintainability etc etc.
But back to the original question: YES!
Cheers, Mike
Reactions: ralphfcooke
When AJ Conti (Basis Audio) was still with us; we ground some of his cast drive belts for uniform thickness; the reduction in "wow" was significant. Basis would go on to offer ground belts. As a concept however if you want to do that you need thicker belts as your starter stock.
Belt thickness has no effect on TT speed unless the belt is so thick and unpliable that it drags down the motor speed, which is highly unlikely.
That's only true if drive pulley and driven pulley are the same radius. However that's definitely not the normal case for a turntable! I suspect in the asymmetrical situation its a complex function of belt compliance, pulley size, belt thickness etc.
Reactions: lcsaszar
