RS:
I can't believe what I just did. Yesterday I posted a long message telling you I was going to to give you the link to an air core inductor calculator. Then, I didn't give you the link!
The men in the white coats should be coming for me any moment now.
Here, at last, is the link:
http://www.colomar.com/Shavano/inductor_info.html
If you are using an 8 ohm speaker and a 12dB/octave crossover, you want the inductor to be about 12 ohms at the crossover frequency. That would indicate an inductor of 4 mH.
Using that program, here are wire guages, forms, etc. to wind your own inductor of 4 mH.
Note: I believe the wire gauges are somewhat different in America and India. Note that the wire diameter, in Metric, is included so you can get the right gauge. I believe the chart is in American gauge wire.
I would post the chart, but it dies not fit with the posting parameters of this BB program. Suffice it to say, American gauge 14 thru 18 are the best choices. The 18 gauge wire has about a third of the cross-sectional area of the 14 gauge, and shoud cost commensurately less-but have higher DC resistance. If possible, try to keep the DC resistance below 1 ohm, even 1/2 ohm if possible.
If forms that fit the model are not available, you can interpolate by the forms that are larger or smaller. Things are not
that exact with this.
