What is your opinion? Is there any feedback in this circuit, or not? Please answer only yes/no!
Thanks, although I asked only yes/no answer.
Then next question: Is it neccessary to lead back every circuit to common emitter configuration, or is it allowed to calculate simple way? (I think it is relevant the statement by Einstein: Everything should be made as simple as possible, but not one bit simpler.)
I try, but I don't know the english technical terminations (or what the heck).
A transistor can be described as 2 gate(?). For example: 1'st gate: base-emitter, 2'nd gate: collector-emitter. There are network equations, for example:
u1=h11*i1+h12*u2
i2=h21*i1+h22*u2
This is the most common, but not the only way! It can be done with common base or common collector too! My 2'nd question: is there any reason to universally prefer one of these, instead of stereotype? I think there is a reason, why is it useful to use the appropiate one, when circuit can be analized simpler with it.
To be continued, actual example come soon!
u1=h11*i1+h12*u2
i2=h21*i1+h22*u2
Yes. There's 100% local feedback in this topology.
With zero beefback, neither local nor global, the gain would be infinite
Pafi said:What is your opinion? Is there any feedback in this circuit, or not? Please answer only yes/no!
Yes - 100% voltage feedback.
Hello! The resistor, is a feedback but then any amplifier has a feedback. (local or global)Speaker too a feedback through the ground.darkfenriz said:1st:yes
2nd:?
Yes, 100 % feedback.
An emitter follower can be seen as an amplifiing device whose feedback input and output are the same.
And I think the not often explained zobel circuit used at the output of amplifiers using emitter followers (or compound pairs) is in fact a high frequency stabilisation component.
An amplifying circuit using apparently no feedback at all was published about two years ago in Electronics Word : it uses a simple common emitter without degeneration and and the load is a chain of diodes.
Distorsion is very small.
~~~~~~~~ Forr
~~~~~~~~ Forr
1: yes
2: not really,
but I guess many guys enjoy matrix maths with the version
u1=h11*i1+h12*u2
i2=h21*i1+h22*u2
2: not really,
u1=h11*i1+h12*u2
i2=h21*i1+h22*u2
forr said:An amplifying circuit using apparently no feedback at all was published about two years ago in Electronics Word : it uses a simple common emitter without degeneration and and the load is a chain of diodes.
Please. Where it can be seen.
To VAD
The circuit was published by S. Chekcheyev in Circuit Ideas, Electronics World, july 2003, page 33. Here's a description :
Power supply : + 6 V
A 1 MOhm resistor from the power supply polarises the base of a BC547A.
The emitter of this transitor is connected to 0 V.
In the collector there is a chain of four either 1N4148 or BC547A connected as diodes (collector to base).
That's all.
Distorsion for 10 mV input when using the chain of the chain of BC547A : 0.0056%.
If the load would be a 110 Ohm resistor, the distorsion would be 0.96 %.
Voltage gain is said to be insensitive to power supply and temperature.
~~~~~~~ Forr
That's all.
~~~~~~~ Forr
forr
I used such a circuit (diodes as collector load) in the mid 70's as an head amplifier for an Ortofon MC20 MC cartridge.
It had very low noise with a BF200 RF transistor.
- Feedback? Vote!
