hi,
what is the advantage of using resistor capacitor series circuit across amplifier feed back resistor from output to bjt base. resistor value normally below 1000 ohms and cap value is around 15pf . lt spice simulation shows increased feed back above 100 khz.![]()
so increased high frequency feedback in negative feedback amplifier reduces gain of input stage for high frequency signal and force the amplifier gain below unity before 180 degree phase shift. am i correct?Yep, that's there for a reason.
As frequency rises, so does the phase shift in the amp. If it has enough gain at the point where the output is 180 degrees out of phase it will oscillate. The cap helps prevent that by decreasing the gain at higher frequencies.
so increased high frequency feedback in negative feedback amplifier reduces gain of input stage for high frequency signal and force the amplifier gain below unity before 180 degree phase shift. am i correct?![]()
[..]this actually increases loop gain, [..]It also reduces the overall amplifier gain at high frequencies.
