Favorite Threads and Posts in "Class D" Forum
diyAudio Editor
Joined 2001
Favorite Threads and Posts in Class D Forum
This permanent thread is a place for links to threads or posts in this particular forum that are useful and/or exemplify the best of DIY Audio.
This is so others- especially newer members can find them. Feel free to post with these links and a brief comment on what the thread discusses. Occasionally the moderators will consolidate them into fewer posts.
how to calculate a PSu for Class D
Here is a very good explanation about calculating a PSuU for Class d amps by Faux French
How to choose the power supply for your class D amplifier module.
Typically less experienced DIYs repeatedly ask about this issue. It is not particularly difficult but requires knowledge of Ohms Law, the functioning of a class D amplifier and a Buck (step-down) power converter and some general electronic overview.
Only one channel (mono) will be considered. If you need two amplifiers (stereo) to operate from the same power supply, you simply double the current capability of the power supply such that also the power rating is doubled.
Important parameters
For deciding the right power supply, the maximum (operational) power supply voltage and the maximum output current (where the over-current protection is activated) of the amplifier need to be known (see the specifications or the chip datasheet). You also need to know if the amplifier operates from a single supply voltage or two symmetrical (+ and -) supply voltages. Next, you have to design for optimum operation with 8 Ohm or 4 Ohm speakers, eventually 2 Ohm speakers for automotive use.
The effective operating voltage
The effective operating voltage (Veff) is the voltage the amplifier can use to generate a sine half-wave.
For class D amplifiers operating in BTL configuration from a single supply voltage it is the single rail-to-ground voltage.
For class D amplifiers operating in SE mode with one speaker terminal connected to ground and a symmetrical supply voltage it is the voltage from one rail to ground.
For class D amplifiers operating in BTL mode with a symmetrical supply voltage it is the voltage from one rail to the other rail, thus, double the voltage from one rail to ground.
This effective operating voltage indicates the maximum peak voltage the amplifier can generate for a sine half-wave. From a sine half-wave peak value to the rms value, the factor 1.41 applies. The rms value is found by dividing the peak value with 1.41.
Though the theoretical conversion factor is 1.41, it is suggested to use the factor of 1.5 when calculating the rms value of a sine half-wave that can be generated from an effective operating voltage (Veff). Then, some output switch drop is taken into account.
As an example, for a BTL-coupled amplifier that can handle a single supply voltage of 36V, the rms value of the sine half-wave that can be generated by the amplifier is 36Veff/1.5=24Vrms.
With the rms voltage of the sine wave signal, the power in a load can be calculated using the expression Vrms*Vrms/Rload. Using the values from the example above: 24Vrms x 24Vrms / 8 Ohm = 72W. Or, for a 4 Ohm load: 24Vrms x 24Vrms / 4 Ohm = 144W.
This way we can calculate how much AC signal power it is possible for the amplifier to generate in the load PROVIDED the amplifier can stand the resulting current.
The maximum current for an amplifier output
This value is more difficult to find in a chip datasheet. Sometimes it is specified as the (peak) current the amplifier can handle at an output, sometimes as the output current where the (over-) current limiter is invoked. Some datasheets are not clear about if the chip can stand the maximum (peak) current on more outputs at the same time.
When we have calculated the maximum output power the supply voltage will allow, we have to compare the resulting current against the maximum current for the amplifier chip. To calculate the maximum peak output current, we simply divide Veff with the load impedance. Veff / 8 ohm for 8 Ohm load and Veff / 4 Ohm for 4 Ohm load.
Using the values from the example above, the peak current value in 8 Ohm will be 36Veff / 8 Ohm = 4.5 Apeak. In 4 Ohm it will be 36Veff / 4 Ohm = 9 Apeak. Let’s assume the amplifier can handle 6 Apeak at the output(s), operation with 8 Ohm load is fine (max. 4.5Apeak) but operation with 4 Ohm load (max. 9Apeak) will result in over-current at a certain output level.
If we know we will use the amplifier from the example above with 4 Ohm speakers, we need to lower the supply voltage (Veff) such that the maximum current at an amplifier output is not exceeded. Reducing the supply voltage (Veff) to 24V means the peak current in 4 Ohm will be 6A and the amplifier maximum current is not exceeded.
Calculating the power supply capacity
When the maximum output power that is possible with a certain supply voltage has been calculated and the maximum current at the amplifier output has been successfully checked, we need to calculate the power capacity of the power supply.
Here, we use the knowledge that a class D amplifier has an efficiency of typically 90%. To be prudent we use 80%.
The classical way assuming test with a constant amplitude sine-wave: The maximum output power from the amplifier is divided by 0.8 (80%) to take amplifier losses into account. Using the values from the example above, 72W in 8 Ohm requires a power supply of 72W / 0.8 = 90W. In 4 Ohm, 144W / 0.8 = 180W.
The realistic way assuming use with music: The power supply capacity (Watt) calculated above is divided by two. Why? Because music has got a “crest-factor” meaning that no music is demanding full power for long. Actually, most music has long passages with rather quiet sound and short passages with powerful sound. Therefore, it is seen as unrealistic to design the power supply for maximum sound level all the time. Clever and competent people estimate the steady-state power supply need to be half of what is normally needed for the maximum power the amplifier can output. The power line decoupling capacitors are handling the need for short but powerful surge currents.
Using the example above with 72W in 8 Ohm will then require only a 45W power supply (half of 90W).
Can we swap 4 and 8 Ohm loads?
Yes, but with two different results. If the amplifier and power supply are optimized (designed) for a 4 Ohm load, you can always use an 8 Ohm load instead – but, you will only get half the output power. No overload. If the amplifier and power supply are optimized for an 8 Ohm load, you can use a 4 Ohm load instead at lower output levels. But at a certain output level, the higher current demanded by the 4 Ohm load will exceed the current capability of the amplifier and perhaps also power supply such that you have an over-current situation.
Therefore, 8 Ohm speakers are the most versatile if you do not need the extra power.
Reactions: ianc13
...noise or hiss problems?..
Here is again a very good path to find the problems with hiss or nosie by FF
Thank you FF !!
source:
https://www.diyaudio.com/forums/class-d/237086-tpa3116d2-amp-1121.html#post5943410
There are important differences between buzzing (hum / net frequency related noise) and hiss (broad-band almost white noise spectrum noise) and their reasons are different. I will deal with buzzing/hum.
Even experienced DIYers can start sweating when they have to solve ground-loop issues. Ground-loop issues vary with every setup such that we cannot just point at a generic solution.
Ground loops often relate to more power supplies in the same signal chain. PC type computers in the signal chain often cause problems.
To find out what (minimum) level you can arrive at, you remove all other signal cables than a cable going to the headphone output of your smart-phone. Let the smartphone play (without charger) but with the volume on the phone turned fully down. The buzzing you have in the speakers with the amplifier volume turned up shows what the amplifier alone can do. With the volume of the amplifier turned up, you often hear a little buzzing (coming from the power supply or radiated from other appliances in the room).
To find out what causes the buzz you have with the full signal path in place, you use a method where you "work your way backwards" through the signal chain.
Working your way backwards in steps:
* All signal cables to the amplifier disconnected. The active input connectors short-circuited. Any important buzz? Remove the short-circuits from the active inputs.
* Connect a signal cable to the amplifier input you most often use. Make sure that the cable ground is well connected to the amplifier. Short-circuit the signal cable in the end away from the amplifier. Any important buzz? Remove the short-circuits from the cable inputs.
* Connect your pre-amp/DAC/PC to the signal cable but do not connect the pre-amp/DAC/PC to power. Any important buzz?
* Connect pre-amp/DAC/PC to power but do not turn the power ON yet. Any important buzz?
* Turn the power to the pre-amp/DAC/PC ON. If you use a pre-amp, short-circuit the inputs. Any important buzz? Remove short-circuits from the pre-amp inputs.
* Connect a source to the pre-amp or a computer to the DAC. No connection to power yet. Any important buzz?
* Connect the source or computer to power but do not turn the power ON. Any important buzz?
*Turn the power to the source or computer ON. Any important buzz?
If there is a buzzing problem, the buzz should appear during one of the steps above.
