Thanks guys, this was looking nice and easy untill those last two posts
looks like I'll have to download that FEMM magnetic modeling package and have a play.
So ideally I need to put as much copper in the motor as possible, while retaining the BL.
I have a sub where the motor has come apart, the top plate and pole piece/back plate glue joins have failed so I have 3 pieces, top plate, pole piece and back plate and 3 magnets still bonded to each other.
The voice coil is 2" dia
The pole piece is 50.5mm outer dia with a 19.5mm dia vent through it and protrudes 19mm above the top of the top plate. so not much room for putting much of a copper ring around there, my plan was to turn the pole piece down by about 1mm and electro-plate this with copper to form the faraday ring, I was planning on doing this over the whole length of the pole piece.
The top plate is 16mm thick and the hole in the centre 56.25mm.
The magnet is made from 3 ceramic 'slugs' 21.5mm thick, 165mm outer dia and 61.5mm inner dia. I was planning on fitting a copper ring in the void between the top and back plates that would fit flush against the inside of the magnets with an inner diameter as close as I could get to the hole in the top plate so its going to be about 4.5mm thick.
I have a couple of motors of dead subs which are to fit 3" VCs and magnets are 8.5" outer dia (BIG) I could look at turning new top plates and pole pieces to use these, this would give me the ability to fit a lot more copper round the outside of the VC and I would expect have a higher BL to offset the increase VC gap.
The sub is a very high excursion design (XMAX of 2" peak to peak but the physical limits are a good bit more) so I could lose the pole vent and replace the dust cap with a phase plug to increase BL maybe.
Any ideas advice etc is most welcome, this is really an experimantal excercise for me to see the effects of faraday rings and see if I can improve on this sub I have.
