I present to 50w amplifier Silicon-chip is very good amplifier. This company has excellent design and electronics, then I give you images to q dare to put it together:
Original link:
Silicon Chip Online - The SC480 50W RMS Amplifier Module - Part 1
Schematic diagram:
Real PCB:
More PCB components:
Amplifier PCB:
Diagram of the power supply:
More fuentre PCB components:
PCB source:
Actual PCB source:
Full liaison amplifier:
PS: The size of the PCB is: 11.72 inches high and 14.71 inches wide. In case you do not check yourself trust.
For the coil there are programs on the Internet that you can generate the data; Luck. .
Example: Pronine Electronics Design - Multilayer Air Core Inductor Calculator
AMPLIFICADOR DE 50W
Original link:
Schematic diagram:
Real PCB:
Amplifier PCB:
PCB source:
Actual PCB source:
AMPLIFICADOR DE 50W
Tony.
