Looks okay to me, you can crimp two cables on each connector with no issues, I do that all the time.
Don't forget that you should be moving the rail side to the bottom (ground planes are topside) to make soldering of the resistors a bit easier. It is manageable both ways though, you can execute as per your wish.
Done, i'll have to practice caps are going to be problem, solder has to flow to other side which will be completely blocked after mounting capacitor.
I didn't realize its that difficult to solder on large plane until i saw video on yourtube "How to solder" 😀
Hi
Ifhe boards are homebrew you shouldn't flip the planes. I assumed they would be PTH, if not you should stick to your original plan.
Re soldering I would recommend a hot in with big tip, and very quick movents. No longer than a second per terminal is needed, and the additional heat transfer gets the copper hot enough for a joint. In fact homebrew boards on 35um have w problems because of the low weight of copper.
I've used a 120w iron to do this task in the past, though even a 50w unit is good but be careful to not overheat the caps.
Hi
It says 1 oz copper(6inch X 6inch), if i don't flip i'll have problem with resistors as well. With flipping it's just caps.
Question
Anyone?
I need just to see if i need to increase copper thickness as ambient temp is very high here. Width is max and on both sides of board.
Need to know roughly how much current flows through F5Turbo V2 PSU diode board traces.
Anyone?
