F.S. Siemens Gle15000/1,5/6
I thought you might like it! Check it out now!
SIEMENS Gle 15000/1,5/6 Half Wave Mercury Vapor Rectifier Power supply ,lot 2
SIEMENS Gle 15000/1,5/6 Half Wave Mercury Vapor Rectifier Power supply - lot of 2 pcs.
Base: USA-Jumbo 4-pin with Bayonet, Top contact with a cap
Filament: Vf = 5 V, If = 9.5 A / Direct
Description Gas-filled high-voltage rectifier: 15 kV blocking voltage, 1.5 A continuous current, 6 A peak current
Weight 300 g
Similar Tubes: Philips DCG5/5000GB, DCG7/6000, G10/4d, RG1000/3000-1,, AEG AG872A, BBC DQ4,
872A, CE-872A, RK872A,.GL872A , VT-42A,
A mercury-arc valve or mercury-vapor rectifier or mercury-arc rectifier is a type of electrical rectifier used for converting high-voltage or high-current alternating current (AC) into direct current (DC).
It is a type of cold cathode gas-filled tube, but is unusual in that the cathode, instead of being solid, is made from a pool of liquid mercury and is therefore self-restoring.
As a result, mercury-arc valves were much more rugged and long-lasting, and could carry much higher currents than most other types of gas discharge tube
