hi!
I have a headphone amp that uses 6SN7 and uses a simple DC heater supply followed by a CRC filter. I'd like to modify this amplifier to allow me to hook up an external wall-wart style (eventually a much nicer supply) to allow me to use 12SN7 tubes. I know there are DC jacks that allow this sort of automatic selection (i.e. when the wall-wart is inserted, this supply is selected). Any ideas on the best way to go about this? Should the jack be between the regulator and existing CRC filter, or after?
Thank you!
Thank you!
I think I'd go ahead and build a simple 12 volt regulated and well filtered supply, which is pretty easy to do. Some of the Wall-warts that I've looked at, on a 'scope, put out some pretty nasty looking "DC". I don't know if all of them do this, but I'd certainly check it out before you use one, as a headphone amp should have a clean DC supply for the filaments. If the filter in your amplifier is set up for 6 volts, it may not survive 12 V, anyway.
The "barrel" power jack should switch between the O/Ps of the 2 supplies. That is it should come after the internal DC heater supply filter.
A Triad VPL 24-400 trafo from Allied Electronics is suitable for powering the external 12 VDC supply. Phase up and connect the dual secondaries into a 12-0-12 arrangement. FW rectify with a MBR20100CT common cathode twin Schottky diode. Filter with a 4700 muF./25 WVDC 'lytic. Follow the filter cap. with a 7812 3 terminal regulator IC. Attach a clip on heatsink to the regulator's TO220 case.
Eli:
Ok, well I have all the parts ready. I ended up going with a different transformer, namely a Hammond 183K12. It is rated at 12.6VCT @ 4.4A / 6.3V @ 8.8. Is it possible to add a 12V / 6.3V switch so my external supply can easily be configured for either heater voltage? I have never placed a switch across transformer secondaries like this, is it ill advised?
ArtG said:I can think of three different ways of doing this, but since you asked this of Eli, we'll wait for his reply. However, meanwhile, how many 6SN7s will you be powering, i.e., what will be the total current draw?
I'm up for all suggestions! I will be powering 3 6SN7 tubes, but wanted a heater supply that I could use for other designs, up to something crazy like 4 EL34. I just asked Eli first, as I already purchased all the parts he recommended.
With further consideration, of the three possibilities mentioned, I now believe that only one would really be practical. I'd suggest a variable regulated supply based on an LM 317. I found the circuit in the link below that's pretty close to what I have in mind.
This circuit with your transformer, and of course, the full wave rectifier, as Eli mentioned, would replace the bridge circuit shown, giving you a maximum output of a little over 12 volts. The input cap (C1) can be reduced to a 25V item, but I'd stick with the suggested 4700mF. The output cap (C3), while not absolutely necessary, is good idea, and can also be reduced to 25V. The "on" indicator LED ( L1, R1), and voltage meter ( R3, P2, V) are also optional, although, again a very good idea, IMHO.
While a continuously variable output is more than what you may need, replacing P1 with a two position switch, and calculating the correct resistor values, would only complicate the supply, and getting the correct values for the resistors, might involve some trial and error. Calculated values, from my experience, seldom produce the exact desired voltage.
The above will work for your three 6SN7s, but it's not enough to power four EL34s. If you want to do this, you would need a "larger" 3 pin regulator (if one is available--I haven't looked), or a slightly different circuit with a separate pass device.
http://www.uoguelph.ca/~antoon/circ/vps.htm
When you cap. I/P filter, approx. 1/2 of the AC RMS current is available as DC. So, figure on 2.2 A. at "12" V. and 4.4 A. at "6" V.
Setting up an adjustable supply overlooks the fact that heating in the regulator IC will be GREAT, when a "6" V. O/P is selected. Remember, the available regulator ICs pass all the current. They are series regulators. If some ingenuity is exercised, the heating in the regulator IC can be controlled.
The MBR20100CT is rated at 10 A./100 PIV X2, with a common cathode. I did not think currents as large as currently under discussion were going to be present, when I made the suggestion. We are talking serious amperage, now. I'm a belt and suspenders guy. Use diodes rated for at least 30 A. I HATE parts failure.
Where a 5 A. rated 3 terminal adjustable regulator in a TO3 case and the MASSIVE heatsink to support it can be sourced is a question to be answered. It may be necessary to use a lower current rated IC combined with external pass device.
BTW, add an additional 10000 muF. of filter capacitance to the circuitry. As the DC draw increases, so must the energy storage of the filter.
...time for me to jump on this thread since it pretty much covers what I wanted to ask anyway...
In order to supply the heaters of an Aikido headphone amp (using 6CG7 and 6H30) I have built a regulator like in the picture attached. It is driven from a 2x9V 50VA toroid, total current draw is in the vicinity of 2,8A!
http://xs123.xs.to/xs123/08054/dc_heater-reg201.jpg
I tested the regulator yesterday (my very first one btw) with a hefty load resistor of 50W, and it works and puts out 6.50V.
I do have to change one of the resistors in the voltage divider to arrive at -like- 6.2V and the dropping resistor which was to big in value and gets mighty HOT.
Is there anything I am missing or what I should be concerned about?
The amp is not finished yet but sits on a breadboard so I have time and space to adjust things. When I put it in a case I don't plan an fiddeling with a heater regulator...
Sorry for threadjacking!
I wouldn't consider your post threadjacking. In retrospect, even, I, myself have been guilty of more grievous sins!
Anyway, I built a supply similar to yours, and placed a multiturn trimmer pot in the regulator, which allows a "fine adjustment" of the output voltage. I mounted this, in a way that it can be adjusted with a small screwdriver through a hole in the chassis. (It's the long blue "thingy" in the attached pix) In your circuit, you could use a 2K trimmer in place of the 1K resistor between the ADJ terminal of the regulator and ground. As Eli pointed out, be aware that as you reduce the output voltage, the heat dissipated by the regulator will increase.
I've also attached a pix taken during the testing of the supply--the world's most tightly regulated "benchwarmer" (patent pending).
Eli Duttman said:When you cap. I/P filter, approx. 1/2 of the AC RMS current is available as DC. So, figure on 2.2 A. at "12" V. and 4.4 A. at "6" V.
I did not realize this
Thanks again!
Eli:
Since my Hammond transformer has dual secondaries, wouldn't the FWCT configuration be for the 12V operation, since the secondaries need to be in series and the bridge configuration be for 6V operation, since the secondaries must be in parallel? I understand how the circuit should work in theory, but this one point confused me.
Should I figure on 2.2A * 12.6V ~ 30W heat dissipation for the regulator, when choosing a heat sink?
luvdunhill said:Eli:
The Hammond trafo has a pair of 2.2 A./6.3 V. secondaries. Wired in series, you get 12.6 V., end to end. To end up with "12" VDC, you need to bridge rectify that 12.6 V. OTOH, to end up with "6" VDC, either you bridge rectify 6.3 V. or you full wave CT rectify 12.6 V. The 4 diode plus switch arrangement I described gets the job done.
Never, ever, change the supply's O/P voltage while it is powered on. Also, be sure to place a bleeder resistor across the filter capacitance. Approx. 15000 muF. store enough energy to burn you, even though the voltage is not that high.
The power dissipated in the regulator is the product of the current drawn and the voltage difference between the "raw" supply and the regulated O/P. The amount of heat produced when 15+ V. is dropped to "6" V. is huge. That's why we are construction a switchable unit. You want to have the "raw" supply be large enough to avoid regulator dropouts and no bigger. Less is definitely more, when it comes to the generation of waste heat.
andyjevans said:LM338 and especially LM1084 are good for 5A. Need tidy heatsinks.
The DC connector range goes up to 5A in 2.1mm and 2.5mm sizes, and the chassis socket should have a switch so it disconnects the internal supply when inserted (usually batteries)
AndyJevans:
Looks like the LT108x will only do 12V maximum output. I'm assuming this isn't close enough to 12.6V for the heater supply?
- Tubes / Valves
- External 12V heater supply conversion question
