Hello,
always struggling to get this deep bass feeling (<40Hz) from my 8" audio nirvana drivers, I was thinking if something can be done to improve their response.
Playing music using VLC player on PC and using it's graphic equilizer, I could boost the bass region below 40Hz and reduce the overal volume, so that a very contained and deep bass could be heard even from these small drivers.
I have successfully tested this on smaller drivers, even 6".
I wonder if a hardware graphic equilizer can be made for the bass region, prefferably analogue, that can precisely control the bass response <40Hz.
All the schematics I have seen on the net control just 50 and 63Hz only
This is exactly what I need!
Thanks!
However, how should I also include the higher frequencies (without passing them through the equilizer)?
Just connect the input source audio to the output in parallel or feed it to the summing opamp?
So an eight inch speaker is small ?
How confusing....and what about its excursion ? If it's in the <5mm range any over-powering in the bass region would produce distortion .
To handle power in the bass region you need 1) excursion which implies 2) a soft suspension, rubber or foam.
Nevertheless, a fullrange is optimized to work well in the passband region of 100-10000 Hz ( let the whizzer cone produce adequate sound in the treble region )
I am not expert, but by lowering down the volume and increasing in software the desired bass region, a very warm desired to my taste bass is achieved even in my Realistic Minimus 7 tiny speakers
