We moved and we'll be in this place for a while, so i'm ready to spend some effort to get things right.
Setup: basement corner room. Concrete floor and concrete exterior walls, room is about 12 x 24 with a 8'/7'/8' ceiling (in ceiling duct bisects the room across the short axis); with open stairwell at back left corner going up, so not truly sealed.
My 'for now' subs produce boomier/peak-ier response than in my last basement HT - and I'm building a pair of enclosures to use my 2x12" drivers - but in the meantime, i'm after an EQ for the LFE channel.
so, i've come across the Rane PE-17 http://www.rane.com/pe17.html - but that's XLR-or-1/4" - does anyone use this model for HT LFE tuning?
do you use one of these? http://www.8thstreet.com/Product.asp?ProductCode=22049&Category=Accessories
the signal chain: the pre/pro is a Sony ES receiver using the pre-outs. the sub amp is either an Acurus A200x3 (using only 2 channels) - or maybe an Aragon 4004 if i can swing the deal - but both have only RCA ins... so i'd have to switch away from XLR or 1/4 back to RCA... UGH.
any ideas?
ie: even this one seems to be XLR (or digital in/out) http://www.behringer.com/DEQ2496/index.cfm?lang=ENG
how do you tame your LFE channel?
any ideas?
