For Sale ENI 300L Class-A Linear RF Amplifier: 3W 250kHz - 110MHz
Things you have for sale.
For sale is a high quality ENI 300L Class-A Linear RF Amplifier
Tested and working perfectly, except for the front panel power meter that doesn't seem to work 🙁
A very handy amplifier for the lab, very compact size and passive cooling so no noisy fan!
Manufacturer's Specifications:
  • Frequency response 250kHz to 110MHz
  • Linearity +/-1.5dB
  • 3W CW continuous output, more at mid-band frequencies
  • Gain is approximately 40dB
  • Harmonics are lower than -20dB at full power, even less at lower output power
  • BNC input, N-type output connectors
  • 220mm wide, 170mm high, 220mm deep
  • Approx 3.2kg weight
  • 240V and fitted with an Australian 3-pin plug
This is a high quality amplifier intended for general lab use
USD 250 + postage
Thanks for looking! 🙂
