Hello everyone,
I want to build a pair of speakers for music listening with the wharfadale super 8 RS/DD. They are in very good condition. Can someone suggest what enclosure best suited for this driver? I try searching on the net but got very few information on it. I mostly listened to jazz and classical.
What is interesting about this driver is that it classified as a wide range which most likely I would need a matching tweeters in order to make this work which I would need your help as well. It's rated at 10-15 ohms again another problem with amplification, any suggestions???
According to other source that I have found on the net is that above around 5khz things started to going crazy. Dispite the fact of high QTS value of 0.63, most people would prefer to be used as open baffle with a larger woofer for the low end. I did a preliminary test on a 25"x25" board to see how it sound and it didn't produce very much low end, probably a larger baffle would improve thing. Vocal and instruments sound pretty good but the whizzer cone sounded very distracted at a distance of about 2m on axis, this definitely suggest some sort of EQing or filtering network. But too big of a panel for open baffle would take too much space in my small room (12ft x 10ft). I would prefer the speaker's to be place in the corner distance at about 10ft apart on a stand.
Any comments or enclosure ideas would be very much appreciated.
Thks in advance.
Thks in advance.
