A new ELEKIT’s vacuum tube amplifier with 2A3 tubes that enjoy deep-rooted popularity among
audiophiles will be released later this year. The model is a single stereo power amplifier with
double amplifications by “6SN7GT” in the voltage amplification stage and “2A3” in the output stage.
Inheriting some specifications seen in current ELEKIT tube amplifiers, such as DC heater supply for all tubes, ripple filter by FET, and R-core power transformer, some new features will be added, such as a space that allows installation of a large oil capacitor, Vitamin-Q for example, without modification, improvement of discharge characteristic by adopting Schottky barrier bridge rectifiers, and separate fuse for L-ch/R-ch in B supply.
Vacuum Tubes 2A3 x 2pcs, 6SN7GT x 2 pcs
Rated output 3W+3W (THD=Rated output 10%、1kHz、when 8Ω)
Rated input 450mV
SN ratio Approx, 102dB, residual noise 0.05mV (when 8Ω)
Frequency response Approx. 10Hz-50kHz (when -3dB 2 W output)
Speaker impedance 4 - 16Ω
Input terminal LINE x 1 (Gold-plated RCA)
Output terminal Speaker output terminal (4-6.3Ω, 8-16Ω)
Gold-plated screw-type terminal
Single/dual (19mm pitch) banana plug can be used.
Power supply AC100V 50/60Hz (3P inlet)
* 115V, 200V, or 230V specification available by changing the connector
position upon assembly.
Dimension W370xH190xD270mm (incl. projections)
Weight 10kg
