Ok, here they go...
Some of the OUTSIDE first
And now the INSIDE...
And you should have seen the piece of junk it was at first.
Took me months
Scorpion
Took me months
Scorpion
Looks like new, was there corrosion?
Corrosion?
It was a real piece-of-junk!!!
It was so burned inside that I had to change A LOT of stuff (too much).
Caps, resistors, cables were toasted. Had to have a new Heyboer PT made. Didn't have much of a choice...
This pic is pretty much the closest representation of how bad it was at first...
A heroic effort.
Thanks but i'd call it a "Dantesque" effort...
I am so pissed the faceplate had a drill hole to the bottom right.
Nothing I can do about it.
Thanks for your comments.
I am pretty much doomed with that hole until I find another faceplate...as I think a toggle or any other stuff would just ruin the beautiful look (IMHO).
I too like it better like this than the original color. Very easy, I used a Tremclad black mat spray can. 3-4 thin layers did it.
As far as the chassis. Once sanded, if you want to bring it to mirror like condition, just use some green ScotchBride and dip them in a bowl containing warm water AND liquid soap (the one for the dishes) and bingo!!
Really easy.
I got that trick from a professional machinist who does stuff for audio manufacturers in my area.
Finally, the female speaker connectors are NOT standoffs. I bought them on Ebay. They are made especially for vintages if memory serves me well.
And very affordable at that....
Scorpion
Really easy.
Scorpion
Or fill it in with liquid metal...
Permatex(R) Liquid Metal Filler - Permatex
Oh, didn't know about it. Interesting idea. I will look into it.
Scorpion
- Tubes / Valves
- EICO Restoration Project
