I'm rebuilding the amps in an Akai/Roberts tube R2R for mic/line/guitar use. The signal hits an EF86 first (originally used to amplify signals off the tape head) before going to a 12AD7 for further amplification.
I'd like to use a pentode/triode switch for the EF86. What I'm really hoping to do, for layout/interface reasons, is wire it as a pull switch on the gain knob. Ideally, that means a 100K pot with a DPDT pull switch. My schematic (for intended pentode operation) says 195V B+, with 47V on the plate, and 65V on the screen at the quiescent point.
That says to me that I need a pot/switch rated for at least 200V. Is this correct? I'm having a really hard time finding this component---the closest I'm coming are some Bourns pots for guitars that are rated to 150V. (Like this---they also only go down to 250K, but I figured I could use a parallel resistor to ground to keep the input impedance down around 100K?)
Thanks. Most of the info I've come across involves switching P/T mode on output tubes, rather than preamps.
-E
-E
I'd use the switch to control a 120VAC relay of the proper rating.
I can't see any reason why that pot/swithc could not be used to switch between triode/pentode at the voltages you told.
To use a relay here is quite extravagant.
Artosalo, is that because the relevant voltage is the quiescent voltage? I'm thinking that when the tube is in cutoff, the switch will at least momentarily see all 195V. Not a constant condition though.
As it turns out, these pots aren't going to work at least. I just heard back from Bourns tech support: the 150V rating is across the pot, not the switch. The switches themselves are only good for 30VDC.
That's typical for most small AC rated switches, and is why I recommended that you use the switch to control a 120VAC relay.
That will work just fine.
Indeed. Though I also thought it was a somewhat extreme solution, given that the payoff is to save the pull-switch design element.
The only reason this is of interest is that I don't want it to be easy to accidentally switch the tube into pentode mode. After a little reading, I'm toying with the idea of just using a Merlin- morph control as a sort of gain knob instead. There's another stage after this one, and each one gets a Big Knob on the front---putting this one on tone-shaping duty seems like an interesting idea.
Surely the DC rating of a switch assumes a relatively low impedance supply so an arc might continue? The anode circuit of an EF86 is going to be high impedance so any arc is going to be short-lived. In this situation I would use a switch up to its AC rating. However, make sure you use a new switch which has never been used to switch power so no arcing has yet occured to damage the contact surfaces.
Arcing is a thing mainly related to the current, not voltage (for example in arc welding you have just about 40 volts, but over 100 amps). I don't think you see such currents with tube amps where this would be an issue.
- Tubes / Valves
- ef86 pentode/triode switch: voltage rating?
