Eclipse?
Larr_e_boy
2001-05-28 4:46 am
Hi.... I'm currently looking for speakers to start a speaker project. I plan to have a sub with two 12" speakers in push/pull, and two satellites with 6.5" speakers in a MTM configuration.
Are the Eclipse 12" W1238R's a good choice... obviously their specs are good (are they accurate?) with an fs of 18 hz. Other speakers with these kinds of stats I see usually are $150 or more... while the Eclipse are around $70. Are the Eclipse a well built speaker that will last very long?
I am planning to use two of them in my sub design so hopefully that will divide the load between the two.... or... Should I just get one of the higher priced speakers and only use that?
Thanks,
Matt
