Hey there, i found this amplifier on ebay, http://www.ebay.com/itm/2-1-TDA7294...mplifier_Parts_Components&hash=item1c2f8021af and for the price i think it's interesting, does anybody have some experience with this amplifier, or does somebody own it?
Thank you
Thank you
Integrated supply means that the bridge rectifier and filter capacitors are mounted on the same circuit board.
IF you were able to find a transformer that gave a peak AC voltage of 40V (recommended from datasheet) and had music that tried to draw full power from one rail on all channels (80W+80W+160W) at the same time you would find that the filter caps on that board would not be able to keep the voltage up high enough to deliver the power.
60W+60W+120W yes...80W+80W+160W not quite. (my calculations)
Buying them this way is easier but limits your options for stiffer supplies.
If you don't need the full power it will not be an issue.
Not to mention that the circuit layout can cause all sorts of noise.
I purchased a TDA7294 Bridged 2ch on E-Bay and there are posts on this forum with directions on how to fix the HELL that is in the circuit design.
A lot of it stemmed from poor power supply design and layout.
I'm pretty new in the "gainclone game" but recently I bought about the same board, but instead of 4x tda7294 it's 2x lm3886 for the midranges and tweeters, and 2x TDA7294 for the subwoofer. The sound quality is perfect, and the chips is definitly genuine. The only con is that there where some poor solidering that I have to fix myself. there where no short circuits, just cosmetic.
LINK:
YJ 2 1 LM3886 TDA7294 68W 68W 160W Amplifier Board Speaker Protection | eBay
I also found this board. It's a little bit more expensive, but have more expensive parts
Assembled TDA7294 2 1 Channel Power Amp Board with Speaker Protection Upgraded | eBay
LINK:
- Chip Amps
- ebay tda 7294 2.1 amplifier sugestions
