Ebay 10 pounders with tubelab pcb's
I have 1 extra ebay 10 pounder power transformer. I believe it does 300vdc and 330vdc unloaded. Is that enough for a standard ul simple PP el84? If i do a simpleSe with el34's in ul what power would i get out? 300 seems a bit low for for a SE build...
Just trying to find something to make out of my 10 pounder and my left over el84's and el34's.
any idea of the current ratings for HV and filament supplies?
well with a 35c rise above ambient he was getting 200ma and 6 amps on the filaments. id say thats a pretty good judgement considering ambient of 25-30c.
You figure 45ma a tube tops for a stereo el84 pp setup. for a el34 SE at 300v your looking at 75ma per tube.
You've got me thinking... I have one of each type of the ten pounders (#7018 and #7019). I wonder if somehow I could cobble one onto my Simple SE and get a ~300 volt B+ suitable for running my old coke bottle 6L6? But alas, the ten pounders lack a center tap. How to make this work?
I suppose I could take the #7019 (235VDC) and use an off-board full wave solid state bridge rectifier. Feed the rectified DC into T1-RED and T1-RED-YEL. Build an octal shorting plug to stick in the rectifier socket, or jumper SW1 and D1/D2. Hmm...
