They are used to isolate the gound holes on the PCB from chassis. Typically 100nF-470nF. Using isolated stand off´s, you might still want to connect these, and then have a couple of wires with "lugs" connected to chassis. Left side of capacitors presumably goes to "ground" on PCB,
