EAD T-7000 CD/LD Player Audio Problem
After a year of sitting in the closet I finally replaced the laser pickup in this broken down CD/LD player. The problem now is there's no analog audio output. It works great as a transport using the digital out.
Is there a button sequence with the remote that switches the unit between digital and analog outputs?
Also, it doesn't play LD disc's. I assume that's because it needs an alignment due to the laser pickup change.
I would appreciate some assistance from someone with whom has experience with the player. Thanks.
David
