Hey,
after building a lot of guitar effects, electric guitars etc. i started to try to understand more on audio equipment. Please tell me if it is not ok to post here but i have the feeling there might the right people around here.
I have an 1980s akg dynamic mic D320b wich has a hubucking coil and a bass rolloff switch.
The mic is in a good optical condition and basically working but: the volume is low and there is no bass. i checked the basic wiring and even dropped out the bass rolloff switch (its just plugged in). Everything seems to be ok.
Then i checked the three solderpads outside of the capsule which seem to be +pol, -pol and humbucking coil(outside the capsule).
Theres a nice drawing in this old manual: http://lcweb2.loc.gov/master/mbrs/recording_preservation/manuals/AKG%20D-320B%20Hypercardioid%20Dynamic%20Microphone.pdf
When i measure the three solderpads i can see they are connected to each other as they should. But the across the diaphragm coil i measured about 300 ohms and across the humbucker coil only about 10 ohms. Could there be a problem? maybe a broken humbucker coil?
I would really appreciate some tips on this problem.
