Hello everyone,
I have recently purchased Dynacord PowerMate 1600-3. Can someone please tell me this mixer would work well (or maybe not at all) with KV2 Audio ESD15? Here are the basic specs for both:
1. Dynacord PowerMate 1600-3
2x 1000 W/4 Ohm RMS
2x 600 W/8 Ohm
2x 1350 W/2.7 Ohm
6 Mic/Line XLR inputs with 3-band semi parametric EQ
4 Mic-/Stereo line combi-inputs with 3-band-EQ
2x 24-Bit stereo effects processor with fixed presets, plus editable and storable user presets
2x FX/AUX for internal effects device
2x AUX Pre/Post switchable
2x Monitor AUX (pre)
Mute per channel
Switchable 80 Hz low-cut
Switchable Voicing Filter per XLR input
Feedback filter for MON 1-2
New 11-band EQ routed to the master channels
B-Master output for recording or mono subwoofer, etc
USB Interface for music playback or output for recording applications (up to 4 tracks at the same time)
Integrated Midi interface in/out
Switched-mode power supply
Integrated loudspeaker protection
Speaker Twist outputs
Volex mains input
2. KV2 Audio ESD15
2.1. System Acoustic Performance
Max SPL Long-term 126dB
Max SPL Peak 132dB
-3dB Response 48Hz to 18kHz
-10dB Response 45Hz to 28kHz
Recommended Power 500W
Sensitivity 97dB
Impedance 4Ω
Crossover Point 500Hz, 2.5kHz
2.2. High Frequency Section
Acoustic Design Horn Loaded
High Horn Coverage Horizontal / Vertical 80° x 60°
Throat Exit Diameter / Diaphragm Size 1" / 1.75"
Diaphragm Material Nitride Titanium
Magnet Type Neodymium
Protection Electronic RMS and Peak Limiter
2.3. Mid Range Section
Mid Horn Coverage Horizontal / Vertical 80° x 60°
Woofer Size / Voice Coil Diameter / Design 6" / 1.5"
Diaphragm Material Epoxy Reinforced Cellulose
Protection RMS Limiter
2.4. Low Frequency Section
Acoustic Design Front Loaded, Bass Reflex
Woofer Size / Voice Coil Diameter / Design 15" / 4"
2.5. Speaker Input
Speaker Input 2x Neutrik Speakon®, Terminal Block
I am also open to suggestions for any other 3-way passive loudspeakers. They would be used in small indoor and outdoor settings.
I appreciate any advice!
Rufad
2x 1000 W/4 Ohm RMS
2x 600 W/8 Ohm
2x 1350 W/2.7 Ohm
Mute per channel
Volex mains input
2. KV2 Audio ESD15
Max SPL Peak 132dB
Sensitivity 97dB
Impedance 4Ω
2.5. Speaker Input
Rufad
