Duratool solder any good?
Element 14 also seems to carry 63/37 from Kester, that stuff should be good but probably a bit more expensive.
As far as cheap solder from China goes, I bought some "Mechanic" brand solder from LCSC in the past and had no problems with it. But if you can still get leaded solder from more reputable manufacturers I would avoid buying from China.
My experience of buying solder has been good and bad.
I bought some cheap stuff from China and it would barely melt.
That would be tin/copper I suspect - unsuitable.
For hand soldering (as opposed to machine soldering), you need a eutectic alloy (and rosin-core)
For unleaded the eutectic composition is 95.5% Sn/3.8% Ag/0.7% Cu,
For leaded its 63% Sn/37% Pb.
Non-eutectics melt grudgingly and are pasty as they solidify. Pastiness leads to dry joints it there is
movement - hence a very bad thing for hand-soldering (probably fine for a wave soldering machine though).
