Dual LT3081 power supply
Joined 2009
Hello,
The power supply is composed of:
1x Avel Lindberg 40/3696 50VA(2x 12v/25va Encapsulated PCB Style Transformer Specifications with Wound Screen
8x C3D03060 Silicon Carbide Schottky Diode
2x Quasimodo filters on transformer secondary windings
2x resistor to form rc filter
12x 4700u/25 Panasonic FC electrolytic capacitor
2x lt3081 1.5a voltage regulator
It can be used only with 230vac on the input
Both regulators are set for 5.2v and were used to power a buffalo dac and a cronus module for about a year, there wasn’t too much heat generated by the heatsinks to affect the nearby caps.
The vregs can be set for a bit more than 11V with 1A max current draw.
I can set the desired voltage first of shipping.
Each of the regs can take 2-3w of dissipation without going hot.
Price 130€
