Ok I have a 300va dual 21vac transformer. I also have a chipamp 3886 kit, and a 41hz amp something or another (takes 20-35volt).
Is is possible to make an external power supply and run both of these from it (not at the same time)?
From the looks, they need to be in series with ct for the gainclone, and parallel for the tripath. I wish there was some magical regulator that would invert 1 channel of the gain clone powersupply.
