Dual Ganged Stereo Volume Control
Hello,
I have a 2.1 speaker system with a RCA/analog Stereo input. This is connected to my TV which has a fixed audio output only, so I cannot control the volume using the TV remote. I have a RCA extension from the TV's output to the speaker input and am planning to add a volume control on this extension wire.
Browsing thru the forum I saw a suggestion to use a "100K Dual-Ganged Stereo Volume Control" 100K Dual-Ganged Stereo Volume Control - RadioShack.com However I noticed the input impedance of my speaker is 4ohms (Z623 Technical Specifications - Logitech FAQ). Will this control work with my speaker system? If not, could someone suggest an alternative? Thanks!
It would be good if u buy a second hand stereo with a working remote control. We can better advice from there on.
One of the simpler option is to rewire your TV audio out after the volume control, may it be any type.
Gajanan Phadte
