Dual-control, sharp-cutoff pentode
Good afternoon everyone,
In a pentode that advertises as a dual-control, sharp-cutoff pentode and that G1 and the suppressor grid, G3 can be used as control elements, if G3 is grounded, does this pentode then act like any other pentode? Specifically I am looking at the 6BV11.
Ray
You need a positive voltage on grid3, like +8V, to get them to behave like a normal pentode:
curves:
http://www.diyaudio.com/forums/tubes-valves/160240-suppresor-grid-used-feedback-6.html#post2083612
https://frank.pocnet.net/sheets/123/6/6BV11.pdf
0 V on g3 causes a large % of plate current to be reflected back to g2. With +8V on g3, most of the current goes through to the plate like a normal pentode. The resulting lowered g2 dissipation should allow the plate diss. to be increased, maybe to 3.5 Watt each. (typical 4:1 rule, 1 Watt less grid 2 diss. allows 4 Watts more plate diss. The plates look more than twice the size of the 3.1 Watt 6BN11 dual P) Should make a decent dual pentode tube with g3 at +8V. Grid 1 gm typically doubles with the g3 mod too (for dual control tubes, more cathode current makes it to the plate). Both tubes on the $1 list.
If applying 8V to G3, would you go through a 1K or so resistor? Would you bypass G3 with a cap to ground?
curves:
