I have been looking for a driver that will cover roughly 100Hz down that will match or better a mid's 95dB sensitivity. I don't use Home Theater and listen in a fairly small space at levels you can easily talk over. To look , I got BassBox 6 Pro as they advertise a large database , which it does have, and they have a function where you can bracket Vb and F3 and search drivers that will suit. Very nice. Except that when I put in a broad range of 100 to 200 litres with F3 = 20 to 35Hz, and check for only available drivers , I get 16 hits , almost all of which the latest data for was 2001 and are no longer available.
My question is broadly, is there another program that you can do a similar thing with that has a more up to date data base? I looked at Vituix Cad and you can scroll through the drivers very nicely with instant graphic results (Very Nice!) but it adjusts the box for every driver and I don't see a way to lock it.
Alternatively , when you know what you want but not the driver to do it, what do you do to streamline your search. It seems that the vast majority of builders use an eq program to take care of any FR issues which I'm not open to doing and there are a heck of a lot of drivers out there to go through.
Thanks very much.
Thanks very much.
