Hi guys,
I`ve been itching to build a karaoke system for a medium sized room, (East Asian style karaoke btw), so I need a vocal sound reinforcment system. I`ve got everything planned out expect for the speakers.
I think a 3-way may be best in this case (tweeter in a horn, mid, woofer), but I`ve been stuck on choosing the drivers. My current hi-fi speakers have not faired well at karaoke, so I`ve focused my search on PA drivers. However, the more I research, the more confused I`m becoming, so I`m asking you for help!
My budget is around $500 preferably less, could be more if convinced
1. The first issue I`m having is linearity. Most PA drivers are not smooth at all. If I want accurate vocal response, will this be a factor in a sound reinforcement speaker?
2. Also most retail karaoke speakers use 8 inch or larger for mids and bass. Why is that? Won`t beaming be an issue?
3. The 6 inch Eminence Alpha-6 is very smooth, but its manufacturer only recommends it for light sound reinforcement duties. Why is that?
4. So what drivers do you guys recommend? I would like a speaker that is very accurate, exhibits good clarity and is revealing of vocals. It has to play fairly loud as well. No drivers larger than 12 inches please, due to aesthetic issues because of where I`m mounting. The lowest octave does not matter too much. (I can fill it in through a secondary connection with my hi-fi subwoofers if neccesary.)
5. What do you think of the Audax PR170M0? What woofer and tweeter would you recommend with it? The description on madisound makes it sound like it`s one of the best PA mids, so I thought I should at least explore this option.
Lastly, I realize I`ve raised some difficult questions, so please accept a HUGE thank you for taking the time to read this post. If you happen to respond, it is very much appreciated.
- mx2
- mx2
