Driver matching (noob here)
Hi ya'll,
On a whim, I bought 2 10" Bravox PXW10D-4 10" DVC Subwoofer 4 Ohm Per Coil from parts express. I want to build a 3 way floor standing speaker from scratch for home use. I would like some direction, literature, or sites to learn from to do this right. I did not realize that there is more to good speaker design than an even frequency response, and I know I'm in over my head without some direction.
Thanks,
-Brian
HI Brian. I don't mind looking all this up...😱
So this is a pair of 10" polycones you have bought...wireable for 8 ohms.
Bravox PXW10D-4 10" DVC Subwoofer 4 Ohm Per Coil 269-520
You have just taken on a massive project, especially since I have no clue what the drivers do in efficiency or frequency response. 😀
Here's how Troels Gravesen does a good 3-way:
3-Way Classic
I suppose you might be looking at something closer to this:
Jenzen CA
I think that's probably doable.
It is usual to choose the mid-driver first...
However, now you've got the woofers, first thing to do is download Unibox & enter the TS parameters so you can work out which size box & tuning works best for them.
However, with an efficiency of 87.6 dB, I'd consider using 2 per side, if that doesn't result in too big a box...
Next, choosing a mid-driver - this has most effect on sound quality, so buy a good one,
perhaps SB or Peerless nomex. If you want to make things a lot easier, you could use a 'full range' driver - no tweeter required. The mid driver needs to have an efficiency the same as the woofer, or ~ 3dB less if you need baffle step correction - are these going to be free standing speakers, or against the wall?
Thanks for the replies,
The frequency response 28hz-2.8khz, but I do not know how linear it is over that range.
I would have normally done all of my research first, but I was up late and wasn't thinking clearly. I don't know enough about matching drivers, this will likely be a long term project, and I want do do it right. I will download Unibox. These will be floor mounted, but I am not sure what size room this will go in, as we will be in a different house by the time these are finished.
I am an engineer, and am not afraid of math or learning new computer software. I am on a budget, but can save up for quality components.
Thanks,
-Brian
Brian, let's be clear. What you have bought (10" polycone bass) has some promise. You just need a clear idea of where it will lead you.
Chartwell PM400 3 way, polycone units, 5" midrange:
Similar to Peerless Peerless HDS PPB 830860
Spendor SP100, 6.5" polycone midrange plus SEAS tweeter:
Peerless 830874
Usually third order tweeter filter if not time aligned. I'd guess you want a couple of cubic feet reflex on the bass.
The second with the Jenzen CA circuit and mid and treble drivers might be good too. These are big speakers for a big room, and best off the floor. 3 ways work better than two ways because they avoid huge excursion on the mid so play louder with less distortion.
