Does audiophile tube builders know what a grid stop is for?
I've noticed a lot of audiophile tube schematics with no grid stop resistor in the circuit.
Do they know what its really used for?
Why do they omit this important piece?
The little graph says it all. They would prefer that graph to remain as flat as possible, as long as possible. If Rg<<Zsource it won’t move much, but the fact that it moves in at all is more than some people can stomach.
But do you really use anything over a 100Khz in the signal? That is where that low pass is. I think it has to do with people not knowing what kind of resistor it supposed to be. Because most resistors are not suitable.
Do they know what its really used for? Why do they omit this important piece?
Very important in our full of RF noise world, for both tube and solid state circuits.
You may get by without it for a while, but things change. And it should have low inductance.
All amplifiers are inherently low pass, it's just a question of where the bandwidth limit is.
Carbon comps should be avoided for some good reasons, like distortion, drift, moisture absorption, loose tolerance, etc.
I would never use them if an alternative is available.
Yes, in general they are $#1+, but even metal film is supposedly “too inductive” for a proper RF grid stopper. I’ve never had trouble with metal film g1 stoppers, but I suppose one of these days I’ll get burned. Like the person who gets burned not using one at all. CC’s just aren’t common anymore and I don’t keep very many on hand. And I use IF strip tubes in voltage gain stages, even with upwards of 30 dB of GNFB. I’ve already run into situations where without g1 stoppers it oscillates, but a cheap resistor fixes it.
It’s in a position where it won’t inject “much” noise at audio. Or even doubling in value being “much” of a problem. Hell, I use MOX films for g2 stoppers which aren’t all that stable either, but they serve a different purpose there.
@rayma,
Are you suggesting the use of these (Vishay PR02-FS) 2 watt resistors for gate stoppers? Mouser has them in values up to 100 Ohm.
Just an option, as I haven't tried them.
But it's best to use a physically small resistor for this purpose, due to lower inductance.
In the neighborhood of 1/4" to 1/2" long, so probably more like 1/4W to 1/2W rating.
Of course if there's gonna be much grid current, the power rating may have to go up.
You want to keep that sensitive node where the grid terminal and the resistor connect together
as compact as possible, and that includes the resistor body.
Over sizing results in lower thermal noise.
Another reason why we build it that way in point to point like in old radios is the mechanical lead strength as well.
These are non inductive and the leads are non-magnetic. A lot of metal film resistors are not suitable for tube applications because their leads are magnetic under voltage. They also stick to the magnet. Non inductive wire wounds don't.
Also, once you use one as the cathode resistor, you probably wouldn't go back to metal films once you hear the night and day difference. Really elevates the tube circuit to the next level.
I would take a few different views. CC resistors are bulk devices and well suited to grid stopper use. They pass no current, so have no excess noise contribution, and size does not effect thermal noise. Hoping that Marcel will comment on the significant part of the circuit inductance, inside the valve.
All good fortune,
Chris
Here's the horse's mouth, Miller himself, in 1919 discussing instability in the grid circuit.
The added external grid impedance should make the total input impedance positive.
