Does anyone have a class D amp they'd like to sell? I'll be driving a some large 8 ohm tower speakers. Let me know specs and price, thanks!
You need to be a little more specific; like giving a price range and if it needs to a completed unit or parts.
I have a couple of class d pcb's that need a heatsink and power supply to finish.
I have a 250 watts peak into 8 ohms class d amp.
I also have a class d amp with a valve front end of the same power.
You can have the first one for £20 + p+p and the valve one for £30 + p+p.
I am not making a profit at those prices.
Hi, yes, I am looking for a completed unit.
I'm not sure what a "valve front end" is.
nigelwright, what brand(s) are these? Do you have any pics? Could you provide links to the components? Thanks.
Anonomous1, I want a great amp at a reasonable price, I don't think class D is going to break the bank.
I am in the USA btw.
They are part of a batch I built for myself. It uses the circuit from the IRS2092 datasheet so is pretty bog standard. Its just a basic PCB around 6 inches by 4 inches.
The valve front end is a ecc82 tube and is used as the amplifier front end. Sounds very clean.
