I've recently purchased a second hand power amp. After setting it all up i found it would powerup but produced no sound, so being the type of guy I am I opened it up.
When I opened it I found that the fuses on the DC rails had blown so i replaced 'em. The new fuses promptly blew the next time I turned it on. Testing revealed that there was >100A(as high as my multimeter would go) between the fuse contacts, slightly more than to 10A indicated for the fuses
I suspect the culprit to be a capacitor between the AC inputs to the bridge rectifier, which seems rather peculiar. I tested the rectifier and it appears to be working fine. The AC from the transformer is fine, I can only find an issue after it's converted to DC.
I'll try to get a picture up as soon as I can, if you guys think it'll help. thanks for any help
