Thanks for the advice guys,
I picked up a 1/4" balanced to rca converter cord at Sam Ash music center. But, now I have another problem. Samson rates it's RCA inputs on it's amps as -10dBV as compared to +4dBV for balanced.
WHat I think this means is that normal home audio rca outputs don't put out enough voltage todrive the amp to full output. In order to get nearly decent power out of the amp (for subwoofers), I have to crank the volume controls on it full throttle and adjust the output on my sub crossover.
Although, this does push the sub amp into clipping territory(clip lights flash) at fairly low output. This sucker is 275wpc channel and should push these 88-90db subwoofers with relative ease, but that's not true.
I suppose I could look into some type of voltage stepup transformer.
Any suggestions?
Does anyone know what the standard max voltage output from pro/live gear is comapred to 2V for home audio?
