Am I nuts, or is the formula wrong?
http://www.diysubwoofers.org/prd/
(Admittedly, the formula could be wrong and I'm nuts too.)
Isn't Sd the effective cone area? In that case, the effective diameter is 2 x sqrt(Sd/pi), right?
I think you're right. Pi R squared is the area of a circle last time I checked. Drop Brian a note.
johninCR said:I think you're right. Pi R squared is the area of a circle last time I checked. Drop Brian a note.
Done.
Sd = pi x Rsquared so Rsquared = Sd/Pi, R = root(Sd/pi).
I can't see where this is claimed to give the effective
diameter, it clearly states this is the effective radius.
🙂 sreten.
🙂 sreten.
