I'm looking to find a DIY spotlight project that can be mounted to a roof and be seen for miles around. Anyone hear of a project like this? Looking at commercial spotlights are somewhat around 155,000 lumens. The cheapest thing I can think of would be to take 4 15 million candle power spot lights (the hand-held recharageable kind) and put them into a smooth drum of some sort to focus the beam.
I'm not really sure how to start on this one, any pointers would be helpful.
DIY idea
Look for a 1000 Watt MH lamp and ballast. I have seen them pretty cheap on eBay, or places like goodmart.com & venture lighting. These are used in parking lots and street lamps.
High pressure sodium is even cheaper to buy and run, but the light will have a funny color. (Maybe you don't care?)
On the other hand, either of these take some time to warm up and restart. If you need "instant on", then a halogen lamp would be better.
Then get a big parabolic reflector from Edmonds for $40 to $78:
http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=1364
Build a nice weather-proof housing with a small 120 VAC fan from Radio Shack, and you are in business. I would make the distance from the lamp to the reflector adjustable, so I could project a tight beam or a wider beam at will.
