I plan to start experimenting with the toner transfer method. I have several questions which I suspect have been answered a million times here, but apparently I don't know how to tell the search tool to find properly
I've been looking at mouser, but am open to better places to look.
Is 1/16" with 1 oz. copper sufficient for solid state power amp work?
Will single sided boards be fine? I have been doing hand wired tube amps up till now, so I'm not sure what can be done on one side without resorting to jumpers. Is there any down side to ordering double sided boards, and "erasing" the copper from the unused side if it turns out I don't need it?
How is a PCB typically cut? The mouser stuff I am looking at is a 1/16" FR4 laminate from MG Chemicals. If I wanted to print multiple circuits on a single board, what is the best way to cut the boards?
I know pro boards have a solder mask layer that keeps the solder where its wanted. I never hear about this being done on DIY boards. Is there no product that one could apply to a board that would allow solder to only "stick" to copper and pins, and not bare fiberglass? Its not a big deal to me, but would be a cool way to get better build quality if it exists.
Along the same line, I know that pro boards aren't individually soldered, but put in a sort of "solder bath", getting quick and extremely accurate results. Again, this isn't a big deal, but it would be cool if there was some sort of DIY method that sort of did the same thing.
What current production cheap laser printers are known to work decently. I've heard that Brother printers are out. There seems to be monochrome printers well under $100 out there from various manufacturers, but I don't want to get something that doesn't work. I have an inkjet that I am happy with for other printing tasks, so this thing would be only for PCB work.
Is etchant solution all basically the same?
As far as ground planes go, is it typical to have a ground plane to serve all the small signal stuff, and have that plane go to some sort of star point while the high current stuff stays off the plane?
Where is the best place to get all this stuff!
It'll waste a lot of etchant solution. You may want to leave most of it there as a ground plane.Is there any down side to ordering double sided boards, and "erasing" the copper from the unused side if it turns out I don't need it?
I haven't tried it, but I have a sneaking suspicion photostats might work (since photocopiers also use melted toner). The idea would be to print it with an inkjet printer, then photocopy that onto the appropriate paper for transfer to the PCB. If that works, there's no need to fork out $$$ for an appliance that just wastes space in your home 99.99% of the time.What current production cheap laser printers are known to work decently.
Maybe smarter people than me will comment on the viability of this.
The problem with photocopiers is that the reproduction isn't dimensionally accurate. They often stretch the image slightly, OK for all-discrete designs, but a problem with thru-hole ICs.
You can usually get someone to make a laser print for you. The alternative is to keep single and doublesided resist coated board on hand and make masks using an inkjet printer on inkjet transparency material. Despite the roughness of the transparency material this works well, but the contrast ratio of the mask is only just sufficient to work, so you need fine control of the UV exposure time. There's a thread here somewhere about building an LED based exposure box with a PIC micro timer.
You can buy all kinds of professional-standard PCB production stuff, but the first substantial problem that you run into is plated-thru holes. If you don't have plated-thru holes then all your connections to leaded parts have to be on the solder side of the board. This is manageable, but you may have to dive the track through the board at the last minute with a manually placed wire via. Making plated-thru holes requires pre-drilling the board, filling the holes with conductive ink, and electroplating them. Then you apply photo etch resist, expose, develop and etch them. To drill the holes you need CNC, and then you might as well go for isolation routing instead of etching.
Thru-hole boards are usually wave-soldered in industry. This is what you would imagine from the name.
The best way to manage things for home production is to use surface mount parts. This cuts down the amount of drilling dramatically. You can use wire vias or just straight links on a single-sided board.
Going to SMT means you can use a toaster oven and solder paste. Solder paste is a mixture of flux and tiny solder balls. You can apply it manually with a syringe or make (or get made) a solder stencil, which you put in registration with the board and squeegee paste onto the pads through the holes. Then you place the parts and heat up the board in the oven until the solder flows, which straightens up any skewed parts by surface tension.
You cut the board using a craft knife to make deep scores in it on both sides. You need a steel straitedge. Work carefully, the scores need to be exactly opposite each other and you must apply a lot of force, so be careful not to cut towards yourself, the blade can break and your hand can slip. Put the board on a sharp table edge with the score lines exactly on the edge, press hard on it with one hand and hit the free section hard with the heel of your hand. Job done.
Finally, look at seeedstudio.com. They do 10 off 50*50mm doublesided boards for U$10 + shipping. They also have a special deal for 100*100mm. If you can wait ~10 days, as opposed to needing the board right now, it's a very good deal.
Fun fun fun.
Fun fun fun.
I suggest you start by reading: Printed Circuits Handbook by Clyde F. Coombs, Jr., ISBN 0-07-012754-0 .
This Tome has plenty of information on Process, Materials and Equipment for commercial PCB manufacturing. Then you can research the Toner Transfer method by going to Google.com , there is a ton of information on this subject.
You can probably get help from the Yahoo "Homebrew_PCBs" group at http://tech.dir.groups.yahoo.com/group/Homebrew_PCBs/
Dale
Dale
Oh, there are multiple types of etchant.
Ferric chloride or ammonium persulphide or muriatic (hydrochloric) acid (spirits of salt) + hydrogen peroxide. The last is handy, because you can get the ingredients pretty much anywhere, whereas the first 2 need to be obtained from a specialist supplier.
Yes.I plan to start experimenting with the toner transfer method.
Commercial products often use single side + lots of jumpers.Will single sided boards be fine? ... I'm not sure what can be done on one side without resorting to jumpers.
Cheaper/easier than going double face, which requires vias and through hole plating, not practical at home.
The added complexity/delay of using jumpers is the least bad solution, by far.
I desigh "double side" but on the top side use only as few tracks as possible and layout those as straight lines, so a simple jumper can replace them.
Any zig zagging is done below.
Yes, you needlessly waste etchant and time, contaminate the Earth, etc.Is there any down side to ordering double sided boards, and "erasing" the copper from the unused side if it turns out I don't need it?
Just answered in another thread.How is a PCB typically cut? The mouser stuff I am looking at is a 1/16" FR4 laminate from MG Chemicals. If I wanted to print multiple circuits on a single board, what is the best way to cut the boards?
I have a 30" blade shear, but if not there I scratch a small notch on each face, using a hard plastic or Formica knife , the one with a blade like a sharp "hook" and a steel ruler and snap it.
With practice it breaks quite clean.
There *is* a photoimageable mask which *can* be home applied, or you can silkscreen it (usually 2 component Epoxy "ink") but it's not worth for home use.I know pro boards have a solder mask layer that keeps the solder where its wanted. I never hear about this being done on DIY boards. Is there no product that one could apply to a board that would allow solder to only "stick" to copper and pins, and not bare fiberglass? Its not a big deal to me, but would be a cool way to get better build quality if it exists.
Personally I coat the bare copper surface with rosin+alcohol flux and a *good* brush.
Protects from oxidation and eases soldering.
Not at home.Along the same line, I know that pro boards aren't individually soldered, but put in a sort of "solder bath", getting quick and extremely accurate results. Again, this isn't a big deal, but it would be cool if there was some sort of DIY method that sort of did the same thing.
I have successfully used many brands, main factor is paper surface , rather than toner.What current production cheap laser printers are known to work decently. I've heard that Brother printers are out. There seems to be monochrome printers well under $100 out there from various manufacturers, but I don't want to get something that doesn't work. I have an inkjet that I am happy with for other printing tasks, so this thing would be only for PCB work.
As far as the image is black, even and without pinholes, it's fine.
So all new printers work well.
Used ones ? .... wouldn't risk one, unles fully tested: draw an A4 letter sized 100% black rectangle in Corel or whatever you have and print it before buying.
This is the hardest task for any Laser printer.
Not at all.Is etchant solution all basically the same?
For continuous production, classic etchant is Ferric Perchloride.
Stains everything, from clothes to skin, eats any metal it touches (except, maybe lead).
For quickies, Peroxide water + Hydrochloric acid , real fast but in practice single use , does not keep.
Toxic fumes, eats everything, even what it does not touch, burns skin, splashes in your eyes can make you blind, so always use goggles and waterproof gloves.
Am I exaggerating?
Not at all, what do you expect from any solution which eats ***metal*** away in *minutes* ??
Watch many Y.T. videos before working, a few are well made.
Thanks JM!
I figured the etching solution would be nasty stuff.
What about tinning? I see that in a lot of the Y.T. videos. Is it necessary?
Also, any experience with transparency paper? I know that the printer needs to support it, but other than that, how is it? I've read you can sort of "preview" the transfer before you completely peel the paper off this way.
I don't understand the PCB fab hobbyist thing - for myself - or to encourage others
employed in 1st world country you can get pro fabbed pth, soldermasked single boards for lunch money
they work to finer tolerance, deal with limited life chemicals, disposal, have protective equipment, are up the safe practices learning curve...
you will destroy cothes with the etchant - worst case chemical burns could blind - have to safely dispose of the unused and waste chemicals
why bother for a poor result?
you should also learn a few hand protoyping techniques: veroboard, point-to-point, "dead bug"...
It's not a PCB fab hobbyist thing. It's an electronics hobby thing. There's just no way to get a comparable result as quickly. Dead bug, veroboard, point-to-point just don't match up. I can have an idea and have a board in my hands an hour later.
I use manufacturers too, I recommended one, it's just a question of horses for courses.
Not at home.
There is. Read my first post.
There are solder pots that create a 4-6" wide flow and are about the size of two shoeboxes (but a LOT heavierAlong the same line, I know that pro boards aren't individually soldered, but put in a sort of "solder bath", getting quick and extremely accurate results. Again, this isn't a big deal, but it would be cool if there was some sort of DIY method that sort of did the same thing.
I guess most people tin to avoid copper oxidation.What about tinning? I see that in a lot of the Y.T. videos. Is it necessary?
Problem is I guess most do it by hand, with a soldering pencil, quite crude, and impractical in a complex or thin tracked PCB.
I much prefer painting copper with homemade rosin flux.
All lasers can print on transparency, problem lies not in the machine but the "paper" itself.Also, any experience with transparency paper? I know that the printer needs to support it, but other than that, how is it? I've read you can sort of "preview" the transfer before you completely peel the paper off this way.
Inkjet transparency melts, sticks to rollers and destroys the machine.
Laser transparency is high temperature mylar.
But I see no advantage in using it for thermal transfer, I much prefer to find a good coated "inkjet photo paper", which has the printing side coated in water soluble dextrin or gelatin (like dessert jelly, but pure, unflavored), so it disolves in warm water.
Practice makes perfect, like everything else.
As of commercial fabrication, for the "modern" experimenter, who builds an Arduino or a DAC or something similar, very complex, multiple layered with hair thin tracks, in a stamp sized PCB, yes, it's better to order from China and wait.
For the (analog) Audio DIYer, who uses "simpler" but much larger PCBs, prices climb real fast, because you pay by the square inch, and the typical "bargain" PCB is only around 2"x2" .
A Robot builder can put a lot there; an Audio guy not much, if anything at all.
Musical Instrument amps typically use a *huge* PCB with "everything inside"
.... even the line Fuse and other live parts (which I find crazy); I *shudder* thinking about what they would cost if ordered singly from China, considering how many 2"x2" units might each be equivalent to.
This Fender example is about 24"x8"
FWIW I make my own PCBs, here's a batch of 36 100W power amps + PSU, air drying the rosin flux coat.
Size: 4"x6" each (equivalent to 6 bargain PCBs each).
Same, being drilled:
@jcx: There are so many reasons, not the least of which is that this is a hobby you know. Sorta defeats the purpose if I pay someone to do it.
For linear audio work, I won't need near the tolerances that a pro fab house can give.
The time is also a factor. Hours instead of days.
As far as dangerous chemicals go, well I suppose I should not work on tube amps any more either since 400v will ruin my day pretty quickly. A hobbyist can be plenty safe. Wear proper gear, pay attention, don't be stupid. There's my safe practices! I do construction for a living. "Safe practices" is 5% common sense that you will do anyway if you have any business near power tools. The other 95% is to protect against the one in a million lawsuit because someone poked their eye out with their hammer.
As far as needing to learn hand prototyping techniques, recall from earlier in the thread I said I have been doing hand wired tube amps. Between that and breadboard work, I think I have "paid my dues" enough to do my own PCBs.
Destroy clothes? I guess if I etch boards bare handed with my church duds on, that would be a problem.
Its not like no one is doing this. Quite the opposite, many are, and no one in the scads of Y.T. videos looks like the toxic avenger with their cloths burning off.
As far as poor result goes, I see plenty of DIY stuff on the web that looks far better than what I require. I suppose if I was doing RF stuff, I'd think twice.
As far as chemical disposal, for my purposes one can of Ferric Perchloride the size of a can of acetone or such should be enough. I realize I need to dispose of it properly, but its not like I have to deal with commercial quantities on a daily basis. More like a small can a few time a year at most.
read contrary opinions for better decisions
that's not right to dangle before beginning hobbyists - after how many hundreds of hours of working at it?
for that fast turnaround you must have secure space to leave things set up - no way to set up, cut, clean stock, print, fuse, mix, heat etchant, clean up after in 1 hr while exercising remotely adequate caution for someone untrained in handling corrosive chemicals - and when did you do the artwork on that time budget
the performance comment is plain wrong - until you get to frequencies requiring defined impedance, matched length trace, lots of them
Linear Technology high speed analog products - some pushing measurement SOTA were often "dead bug" - see Jim William's app notes
http://cds.linear.com/docs/en/application-note/an47fa.pdf
I seldom have the patience to hand proto more than one channel - but I do hand prototype when I'm not using fine pitch smt
and then leave some space, extra pwr, gnd holes, NC pads on your 1st pass PCB layout
Moos - you know your interests - but many of these threads seem to just jump in as if there is no other option to home etching
Per:
>The Alexander amp is a high speed design so I think the physical design is really important. No hard wiring!<
If you combine hardwiring (component leads only, no separate wires) with low-impedance ground and power planes, and design a tight layout, you can make some pretty high-bandwidth circuits. I've designed and built all-discrete 600MHz amplifiers like this.
If anything, I find it easier to go faster using 3-dimensional circuit structures rather than keeping everything on the pcb (2D). A calculated mixture of smd, leaded board and 3D also works well, and is how I normally design.
hth, jonathan carr
What, you mean, like, complete miswiring is not a performance issue?
The big advantage of a PCB, given the technology I use, is that if you draw the circuit right, the connectivity on the PCB will be right.
This is not something to lightly dismiss in terms of the overall effort involved in construction, the greater likelihood of getting it right first time with all that that means in terms of positive feedback, and the savings in debug time and destroyed components.
I would also add to jcx that I am not a "beginner in the hobby". I have been doing tube guitar amps for awhile. Its just that now that I am getting into solid state power amps,, PCBs seem like the obvious next move. If I were completely new to electronics, I likely would not be asking about PCB work, although the more I read about it, the more I feel I should have tried it sooner.
It appears to me that many people are doing PCB's cheaply, easily, and with good result at home. Its hard for me to understand why its not a good way to make the hobby more DIY.
@JMFahey: So I assume that's one channel per board in those photos, yes? And the PSU is on the same board? This is one area that keeps amazing me.
With a tube guitar amp, to me the schematic always looks way simpler than the built product. With solid state, I look at a schematic, and can't believe how "clean" its pcb looks!
I hope I can get boards as least as good looking as yours. Tell me about this home made solder flux.
@JMFahey: I saw one video where it was some product called "liquid tin" or such, and it was a bath that the board was put in. Any thoughts?
Yes, it's so damned expensive I didn't even use it at work.
Oh, one advantage of modern etch resist is that you don't have to clean it off, it continues to keep the copper in pristine condition and you can solder clean through it.
- Design & Build
- Construction Tips
- diy pcb materials
